It is currently Fri Nov 06, 2026 6:42 pm
Vehicle: Vit swb 95
Post Posted: Wed Oct 31, 2012 3:06 pm
Hey guys,
So after the 2" body lift i need to lift the front bull bar.
From what i can see, this is going to be tuff....
So..
Currenty,
The Bull bar is Mounted with 4 bolts onto the chassy, To move this part up is easy (I just need to make 2" plates, weld them on, ect ect...)
The confusing part is... Currently the bottom of the bull bar is held on via 2 U bolts.
These bolts go around a Cilinder like part on the chassy..
Question is,
How do i fix this part???!!!!
PICS TO COME!
Extra info:
CAR: SWB Vitara - 1995
Bull bar: Unknown, (looks like ARB but is NOT an ARB bar(from what im told))
Thanks,
Sam
Post Posted: Wed Oct 31, 2012 3:23 pm
looks like an ARB bar in your build thread, what makes you think it's not?
Vehicle: Vit swb 95
Post Posted: Wed Oct 31, 2012 3:27 pm
Yeah i think it looks like one to?
As i said (As ive been told) by a 4x4 shop :S
They also said it isnt the right bar for my car... i said they are idiots..
(Guy didnt even realise i had a body lift till i told him why the bar was sitting so low) and yes... he could defs see the blocks..
Post Posted: Wed Oct 31, 2012 3:46 pm
have a look at BRAD's brand new ARB bar in his thread, apart from being a winch bar it's identical.
all mounts will need to be extended 2" should be pretty straight forward.
Vehicle: Vit swb 95
Post Posted: Wed Oct 31, 2012 3:52 pm
Only problem is ill have to cut the bottem mount off the bar(the circle one, and re weld it with a spacer?
Might just sell it and make a tube bar if it comes to that...
Post Posted: Wed Oct 31, 2012 3:58 pm
post pics of the mounts, can't be that hard.
Vehicle: Vit swb 95
Post Posted: Wed Oct 31, 2012 4:00 pm
I will leaving work now.. ill get pics up soon
Post Posted: Wed Oct 31, 2012 4:50 pm
If the mounts are welded to the bar itself then yes, you'll have to cut and extend the bottom mounts from memory. They are a PITA on the early shorties.
Users browsing this forum: Google [Bot] and 56 guests
