| ncop just had to post this up https://auszookers.com/forum/viewtopic.php?f=5&t=36809 |
Page 1 of 2 |
| Author: | tanshi [ Thu Nov 01, 2012 1:38 pm ] |
| Post subject: | ncop just had to post this up |
Off-Road and Goods Vehicle Wheel Track The wheel track of off-road four wheel drive vehicles and goods vehicles (MC, NA, NB ADR category) must not be increased by more than 50mm beyond the maximum specified by the vehicle manufacturer for the particular model. If a solid axle from another manufacturer is used, the wheel track may be increased by 50mm beyond the maximum specified by the vehicle manufacturer for that particular axle, provided all other requirements such as clearances and the tyres do not protruding outside of the vehicle |
| Author: | tanshi [ Thu Nov 01, 2012 1:41 pm ] |
| Post subject: | Re: ncop just had to post this up |
looks like NCOP has made my build easier rather than harder!! |
| Author: | SierraDan [ Thu Nov 01, 2012 1:42 pm ] |
Nice! I like it. |
| Author: | just_cruizin [ Thu Nov 01, 2012 2:12 pm ] |
so how much wider are hilux axles then WT axles |
| Author: | SierraDan [ Thu Nov 01, 2012 2:28 pm ] |
From memory 60-65mm a side? |
| Author: | tanshi [ Thu Nov 01, 2012 2:30 pm ] |
from the axle widths thread on here. Hilux (79-85) Front 1397mm Rear 1397mm Sierra WT Front 1340mm Rear 1350mm |
that wms to wms not including wheels |
| Author: | SierraDan [ Thu Nov 01, 2012 2:31 pm ] |
tanshi wrote: and
Hilux (86- ) Front 1397mm Rear 1473mm |
| Author: | tanshi [ Thu Nov 01, 2012 2:41 pm ] |
1410 with wheels from what i can find and sierra had +5 wheels so i would think that makes it around 1387mm centre of wheel to centre of wheel |
| Author: | shep [ Thu Nov 01, 2012 2:59 pm ] |
Aren't coily diffs wider then WT? |
| Author: | Reubs [ Thu Nov 01, 2012 3:06 pm ] |
shep wrote: Aren't coily diffs wider then WT? Yup! ...the reason they had greater positive offset rims out of the factory... |
| Author: | tanshi [ Thu Nov 01, 2012 3:08 pm ] |
yeah, its about 15mm a side or similar |
| Author: | shep [ Thu Nov 01, 2012 3:16 pm ] |
Well that is anouther 30mm ya can go wider |
| Author: | SierraDan [ Thu Nov 01, 2012 3:19 pm ] |
would that be 30mm wider just for coilys though? |
| Author: | tanshi [ Thu Nov 01, 2012 3:21 pm ] |
yeah different model number. but you can mod plate coily diffs under a leafy if you wanted too. or just put MOGs under there |
| Author: | Aaron [ Thu Nov 01, 2012 3:31 pm ] |
does it say anything in regards to SPOA or are you intending on going SPUA on the lux diffs? |
| Author: | tanshi [ Thu Nov 01, 2012 3:34 pm ] |
i havent seen anything re SPOA, i guess it would be possible now. max lift is 150mm but you need to do lane change tests etc |
| Author: | Teracis [ Thu Nov 01, 2012 4:22 pm ] |
So how does that go for putting WT diffs under an NT? Shouldn't be any drama at all? Or completely not allowed because it's the same manufacturer... |
| Author: | tanshi [ Thu Nov 01, 2012 4:23 pm ] |
mod plateable as a diff swap |
| Author: | Teracis [ Thu Nov 01, 2012 4:25 pm ] |
tanshi wrote: mod plateable as a diff swap Woo, I thought they already were because anto86 was talking about doing it but it's good to hear confirmation! |
| Author: | tanshi [ Thu Nov 01, 2012 4:30 pm ] |
they technically were allowed but within the old rules you were supposed to only be 50mm wider than the original diff. WT is 90mm wider than NT so you should run inset wheels to get back to 50mm now you dont have to |
| Author: | KEENSY85 [ Thu Nov 01, 2012 6:18 pm ] |
Is all the new ncop stuff passed yet, I thought it was still in the works. Or have got left behind and it is in action known? |
| Author: | mrw82 [ Thu Nov 01, 2012 6:26 pm ] |
Effective as of today. |
| Author: | KEENSY85 [ Thu Nov 01, 2012 6:55 pm ] |
Got a link to check it out? |
| Author: | DarkHorse [ Thu Nov 01, 2012 8:57 pm ] |
http://www.google.com.au/search?client= ... iQfV-YHYAw
| Author: | KEENSY85 [ Thu Nov 01, 2012 9:03 pm ] |
There dated for Jan last year |
| Author: | Mickc [ Thu Nov 01, 2012 10:21 pm ] |
Aaron wrote: does it say anything in regards to SPOA or are you intending on going SPUA on the lux diffs? Keeping it legal... thread JCB wrote "Leaf spring suspension must not be raised through the use of extended shackles, adjustable metal plates or by placing the leaf springs to the opposite side of the axle" Is this a reference to SPOA? |
| Author: | KEENSY85 [ Thu Nov 01, 2012 10:38 pm ] |
I think so but it's all very confusing |
| Author: | DarkHorse [ Thu Nov 01, 2012 10:41 pm ] |
Alright, fine... http://www.tmr.qld.gov.au/~/media/Safet ... ns1112.pdf or http://www.tmr.qld.gov.au/Safety/Vehicl ... tions.aspx QCOP can be downloaded in sections about 2/3 of the way down the page. VSB14 which became NCOP: http://www.infrastructure.gov.au/roads/ ... _ncop.aspx Approved inspection station code of practice: http://www.tmr.qld.gov.au/Safety/Vehicl ... ctice.aspx Happy reading! I'm off to find the NSW version... |
| Author: | KEENSY85 [ Thu Nov 01, 2012 11:05 pm ] |
Very good Darkhorse |
