It is currently Fri Nov 06, 2026 11:10 am
Vehicle: Lwb vit, 31's big white fridge
Post Posted: Sun Feb 03, 2013 2:15 pm
Help!!
Wheel came off today on the way to the 4wd tracks
Got it back on and tow trucked home
Threads on the axle are stuffed.
I need new brakes- drum- axle studs and wheel studs/nuts
Possibly new axle housing as the Lower shock mount is bent inwards quite badly compared to the other side.
How can i tell if the axle housing is bent?
Post Posted: Sun Feb 03, 2013 11:08 pm
that sucks, measure to a fixed point somewhere along the chassis on both sides. do it in a few directions to, if your numbers dont add up to be the same then its bent.
Post Posted: Mon Feb 04, 2013 7:31 am
I can't see how that's bent the axlehousing.
Vehicle: 2002 Suzuki XL7
Post Posted: Mon Feb 04, 2013 9:22 am
Photo?
My rear wheel came of not long ago, ive gone a bit obsessive now making sure every wheel nut and bolt under the car is tight now..
Only had cracked drum and had to put all the parts back in as fell out, along with new pads.
Post Posted: Mon Feb 04, 2013 9:57 am
check his build thread, and also.. what I did to my zook today thread....
Post Posted: Tue Feb 05, 2013 5:00 pm
Ok I'll measure up tonight when I'm down in the garage.
Users browsing this forum: Google [Bot] and 19 guests
