Hi guys I'm in the middle of putting rear speakers. One source online says that the wire with the black stripe is positive however the speaker cable says the black stripe is negative anyone able to tell me?
Joined: Wed May 26, 2010 3:01 am Posts: 2979 Location: Sunshine Coast
Posted: Mon Nov 05, 2012 3:34 pm
at the end of the day doesnt really matter if u plug the positive cable on the positive or negative plug... it still going to work, the difference is instead to have the speaker go "forward-back-forward", it would go "back-forward-back", making the same sound.
what it really matter is that you plug the left and right speakers on the same concept... so if u use the "solid color" cable for positive(or negative) on the "L" speaker, do the same for the "R" speaker, so both move on the same pattern, otherwise you'll have sound and frequencies cancellation as a negative sound wave would meet a positive one
same principle aplies for front and back speakers... just use the same color code cable for the same plug on each speaker and ull be fine
Users browsing this forum: Google [Bot] and 53 guests
