https://auszookers.com/forum/
GV 4.3 R&P onto Vitara front diff center?
https://auszookers.com/forum/viewtopic.php?f=5&t=3761
Author:  gravity_powered [ Wed Jan 07, 2009 9:55 pm ]
Post subject:  GV 4.3 R&P onto Vitara front diff center?
Will the stock manual Grand Vitara 4.3:1 ring and pinion work with a front vitara diff center in a GV diff housing?
I want to convert to the earlier manual hub system but keep the stock ratios.
Author:  royce [ Wed Jan 07, 2009 10:01 pm ]
Post subject:  Re: GV 4.3 R&P onto Vitara front diff center?
I guess it will be like fitting an airlocker to a GV, the right hand cv wont clip into place but that isnt too much of a concern
Author:  steak_knife [ Sun Jul 12, 2009 4:02 pm ]
Gravity powered, did you end up doing the swap?
& Royce, wouldn`t the cv pull out when the r/h wheel is cocked?
I want to do the swap after frying my 4wd control module in the middle of nowere fri nite. if I don`t run the module I can`t burn it out again!!!!!!
Cheers.
