It is currently Wed Oct 21, 2026 9:45 am
Vehicle: MY2019 Jimny
Post Posted: Thu Jan 08, 2009 9:31 pm
G'day - Through my various searched I have amassed some info regarding my diff, which I believe is 5.12.
To get a 5.12 ratio in a sierra requires 5.12 side gears from a vitara front diff, correct? Any model in particular?
Will a Sierra lockrite work with 5.12 diffs?
I get a clunking sound from the diff when I reverse at times, and sometimes moving forwards, what would you say is damaged? Don't say the diff...
Thanks Y'all!
Post Posted: Fri Jan 09, 2009 2:01 am
with vitara front 5.1's they are the same id and bolt pattern as sierra 3.9's and 3.7's. so to get a lockwrong into it you would use a 4 pinion carrier from an early 1.3 sierra.
Post Posted: Fri Jan 09, 2009 2:19 am
So it is possible to put in a complete vit centre, not just change side gears?
I sorta want to know what I have before I pull it apart, and have a spare ready in case I do find chunks missing...
Post Posted: Fri Jan 09, 2009 2:41 am
your wanting to put a sierra lockright in a vitara? or vitara diff in a sierra?
Post Posted: Fri Jan 09, 2009 2:44 am
I want to put a Sierra lockrite into my Sierra, which I found has 5.12 ratios...
Post Posted: Fri Jan 09, 2009 3:52 am
sorry to butt in on your tread
Joe can you just fit the ring gear into the sierra nt diff or do you need the pinion gear as well?
Also is only the front ring and pinion from the vitara compatable?
thanks andrew
Post Posted: Fri Jan 09, 2009 3:56 am
the rear vit is physically larger, so won't fit.
Post Posted: Fri Jan 09, 2009 4:05 am
any idea on the ring and pinion?
one or both gears?
Post Posted: Fri Jan 09, 2009 2:53 pm
8O
You need both mate..Otherwise a (your?)3.9 pinion will chew the 5.12 ring 8O
(i thought everyone knew this) 8O
Post Posted: Fri Jan 09, 2009 3:44 pm
i had 5:12s in my old soft top zook and thought it was pretty good gearing.Just used two front diffs as obviously rear just wont fit :lol: i done it the stupid way and just bolted in the complete centres alloy housing and all,allthough it held up on my zook a mate tore the alloy to bits and ran it up through his tray with his tailshaft.So id go about putting the ring and pinion in the sierra centre and probly go a 4 pin up front while im at it,which you would need for a front locker anyway.
ajsr you need to change both,im pretty sure both ring are 41 tooth but the pinion is different,8 & 11???????? and the spacings between gears are different so no it wouldnt work mate
Post Posted: Fri Jan 09, 2009 8:50 pm
you don't need a 4 pin carrier to fit a lockright.
they make a lockright for both 2 and 4 pin diffs, i have one in my
front diff which is a 2 pin center.
Post Posted: Fri Jan 09, 2009 9:04 pm
8O
ouch blue sorry it was getting late and I was obviously not thinking silly me :finger:
Post Posted: Fri Jan 09, 2009 9:56 pm
So a lockrite will fit both carriers then?
Post Posted: Sat Jan 10, 2009 12:48 am
obviously will, i thought i was told you needed a 4 pin,or is that only for a airlocker????come on we need this cleared up :lol:
Post Posted: Sat Jan 10, 2009 1:02 am
the lockright that comes without coupler will fit both types of diff
the one with coupler is for 4pin. actually the big thing is that the coupler only fits the spline of the rear axel.
the lockright with coupler is the better locker and a coupler cant be added to the one without.
Post Posted: Sat Feb 21, 2009 3:49 pm
so what is the best way to do this?
1. Put the whole vitara diff centre into a sierra housing?
2. Put the vitara ring and pinion into the sierra diff centre?
What type of diff do i need for this to be compatible? (2 or 4 pin)?
Can an airlocker be put into either diff?
How many pins are standard WT diffs?
Vehicle: LJ50V, SJ70
Post Posted: Fri Aug 21, 2009 12:30 am
Although the rear Vit HOUSING is physically larger, the F and R Ring and Pinions are identical, except for the GV which has a larger R&P in the rear. Using a rear Vit centre with the ring still attached and transferring that and the pinion into a Sierra is the way to get a 4 spider centre with 26 splines. If you want a 4 spider centre for the front, the 22 spline side gears from a 2 spider front centre will drop into the 4 spider housing.
Post Posted: Fri Aug 21, 2009 12:45 am
ummmm.....are you serious?
rear vit ring and pinion will not fit a sierra carrier. if you want 26 spline 4 pinion diff then just bolt you're existing carrier on to the vitara front ring gear......and all lockers will work too!
p.s.........gv (not xl7) ring gear diameters are the same as early vit ring gears.........the only dofference is that grands have a smaller internal diameter.
that was a good one............... :rofl:
Users browsing this forum: No registered users and 76 guests
