It is currently Fri Nov 06, 2026 2:45 pm
Vehicle: 96 vit hardtop
Post Posted: Sun Dec 30, 2012 11:10 am
Hey guys
I bought the supercheap winch 9500lb's today, as they were half price $349.
I want to swap out the cable with dyneema rope to save on weight.
The steel rope is 28meters. I was wondering if anyone swapped it out and if they were able to put more length in there. I was thinking bout going 40meters, but unsure if it will fit.
Any help appreciated.
Vehicle: sj51
Post Posted: Sun Dec 30, 2012 1:09 pm
I previously ran 50mtrs on a lowmount, it was dynamica brand 8mm i think... 31zook might chime in here
Currently i have cheepo 10mm on my m6000 and the 28mtrs fills it..
I'd much rather the dynamica rope i previously had... but im a cheap skate...... i knew i shouldnt have sold it
Post Posted: Sun Dec 30, 2012 1:58 pm
And now I have it!
It's only 30mtr and it only just fits on my 8000lb warn lowmount.
Post Posted: Sun Dec 30, 2012 3:50 pm
Steel cable is generally 6mm, whereas Dyneema is usually 8-10mm. So while it does compress a little, it takes up marginally more room than the equivalent steel length.
I'd get 30m to store on the winch, then either an extension strap or another length of Dyneema with eyes at each end.
Post Posted: Sun Dec 30, 2012 5:23 pm
Wat which runs 6mm cable
Dont most run 10-12
Vehicle: sj51
Post Posted: Sun Dec 30, 2012 5:36 pm
And now I have it!
Truly? Sorry josh, I thought that was my 50..
Post Posted: Sun Dec 30, 2012 6:17 pm
Dont most run 10-12
Maybe, but in this application the winch runs 8.3mm. I think ill stick with a 28 meter and then just get an extension like one of the boys mentioned.
Post Posted: Sun Dec 30, 2012 6:26 pm
pezz wrote:
And now I have it!
When I showed up you told me about it being 30M and asked if it was okay...
Forgot about it rabies?
Vehicle: sj51
Post Posted: Sun Dec 30, 2012 8:33 pm
pezz wrote:
And now I have it!
Fook im getting old :(
Post Posted: Fri Jan 04, 2013 2:31 pm
Another qn.
Can you replace the cable with the winch still fitted to the car, or is it a 'bar off/winch out' job.
I've seen a vid where the guy did it while it was on, but couldn't see close enough to the detail involved in removing the cable.
Wanna fit the winch this weekend, but dont have the plasma rope yet....
Cheers if anyone knows.
Post Posted: Fri Jan 04, 2013 4:14 pm
Depends if you can get your hands in with the bar etc installed. Is it just a simple winch lug that anchors the rope on the drum? If so it's pretty simple if you can physically get in there.
Post Posted: Fri Jan 04, 2013 7:34 pm
Mine is tied to the drum wrapped up a heap of times then marked so I don't spool out past it.
Vehicle: sj51
Post Posted: Fri Jan 04, 2013 8:24 pm
I second the tie off method, i have mine bolted on the looped around and tied,
marked when there is one full set of wraps covering the whole drum..
Its recomended to have a full drum on with rope as aposed to 3 or 4 wraps( half drum) for wire...
Dyneema is slippery stuff!
Post Posted: Sat Jan 05, 2013 7:09 am
Supercheap also sell the rope replacement and they have 20% off store wide today
Post Posted: Sat Jan 05, 2013 4:22 pm
I pulled the bolt out of my winch rope on the first long winch that I did so mine is also tied onto the drum and then duct taped down tightly for about 4 or 5 rotations of the drum. Also to help the rope slipping on the drum we put down a few layers of tape back to back straight on the drum before the rope. After you use it with the tape on there it gets warm and sticky and holds the rope tight.
Post Posted: Sat Jan 05, 2013 5:01 pm
saw the add just after lunchtime today, scooted off to the local & cleaned up... bought shit loads of consumable stuff, stocked up on oil & a few other goodies.
Post Posted: Sat Jan 05, 2013 5:06 pm
yeah was there this morning and it was bloody packed. Got the things i needed too. :)
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat Jan 05, 2013 8:13 pm
no trouble replacing the cable with the winch on.the end of the steel cable has this to connect to a screw on the drum.
i had 2 of these ridge rider 9500lb winches. both had the same gearbox issue. supercheap planed on putting the gearbox from the 12000lb winch onto the 9500.
if your winch lever doesn't turn 360 degrees clockwise to the starting point, and instead turns 180 to engage then anticlockwise to disengage you have the older model and i would highly recommend taking it back.
also, the 12000lb comes standard with a synthetic rope. its 10Kg lighter according to qantas...
Post Posted: Sat Jan 05, 2013 8:42 pm
Yeah ur right. The first one I bought came with the old style clutch which is chrome and the lever is also closer to the drum. It also doesn't come witha wireless controller. I returned it as I had an issue with the clutch not engaging. When I replaced it I got the newer one where the clutch lever spins all the way around and is also at the point furthest from the drum. Its a much nicer design and engages very well. It actually clicks and locks into place. Good heads up.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat Jan 05, 2013 9:17 pm
should have broke it sooner, they swapped my 9500 for a new 12000 XD
Users browsing this forum: No registered users and 79 guests
