It is currently Fri Nov 06, 2026 1:09 pm
Post Posted: Sun Jan 06, 2013 10:06 pm
Does someone have a vit front with the alloy barrier they could weigh? Not the whole housing just the centre assembly.
Also would like to know the weight of a vit rear. I'm comparing to a sierra centre (which I have)
Thanks!!!
Post Posted: Sun Jan 06, 2013 10:08 pm
viewtopic.php?f=5&t=23448
page 2 has vit weights
Post Posted: Mon Jan 07, 2013 8:28 am
i can weigh one thurday night if you still need it.
Post Posted: Mon Jan 07, 2013 9:35 am
Thanks man. Can you add the info to that thread that Atari posted?
Do you have a front with the alloy carrier too?
Post Posted: Mon Jan 07, 2013 9:42 am
yep, alloy one with a 4.8
rear centre with a 4.6, they will vary a little with diff ratios, but not too much
Post Posted: Mon Jan 07, 2013 9:46 am
from that thread....
4.6 Rear diff centre & gears - 23kg
Vit alloy front diff with centre - 20.9kg ~ i'm not sure if that's with the housing. but that would would only weight a 1kg or so, there isn't alot of weight in the housing.
Post Posted: Tue Jan 08, 2013 9:37 am
That would be fabulous, thanks darl pompoms
Post Posted: Tue Jan 08, 2013 12:24 pm
That 20.9kg is a complete housing, the one that came out of the SV with your centre in it Gus, so 4.8.
Users browsing this forum: Google [Bot] and 56 guests
