| SJ50/Drover radiator fan coupling...viscous? https://auszookers.com/forum/viewtopic.php?f=5&t=38237 |
| Author: | droverdave [ Thu Jan 10, 2013 4:15 pm ] |
| Post subject: | SJ50/Drover radiator fan coupling...viscous? |
Hello all, Currently completely a resurection of an 85' holden drover. Ive noticed that the radiator fan is directly connected to the water pump pulley, i just got the engine going last night after a rebuild, and i think id prefer a viscous coupling to slow the poor fan down. Does anyone know if there is a viscous coupling that can be used in its place easily? And will this suit the standard radiator/shroud? ie will it change the offset of the fan in relation to the radiator? I dont have a shroud at the moment (looking to buy one though). Not a big issue i suppose, but i think id prefer the viscous coupling over the fixed coupling. Any help would be muhc appreciated. edit: i just read that the later model sierras have a viscous coupling? is this true? |
| Author: | atari4x4 [ Thu Jan 10, 2013 4:17 pm ] |
| Post subject: | Re: SJ50/Drover radiator fan coupling...viscous? |
vitara viscous hub |
| Author: | Gwagensteve [ Thu Jan 10, 2013 4:35 pm ] |
Coil sierras might have had a viscous clutch, but as per atari's comment - you want a vitara fan and hub. Much biggerer Steve |
| Author: | droverdave [ Thu Jan 10, 2013 6:09 pm ] |
That sounds quite excellent. apart from the fact they are like 150bucks new! i think i will learn to live with my fixed fan unless a cheap one comes up. so the vitara viscous thingy, aka this: http://www.ebay.com.au/itm/Fan-Clutch-a ... 35b2fecda7 and a vitara fan suits this, my radiator, and my standard drover radiator shroud? |
| Author: | atari4x4 [ Thu Jan 10, 2013 6:14 pm ] |
find a 2nd handy & reco' it. viewtopic.php?f=17&t=28644 there are a few vits getting wrecked on here, have a suss through the forsale section. |
