It is currently Fri Nov 06, 2026 1:28 pm
Post Posted: Fri Jan 11, 2013 7:03 am
Please forgive my total noobness.
I have an LWB vitara, lifted around 50mm. I have read lots of posts around lifts, and it would seem a Diff spacer (third arm - or heim spacer as the US seems to call them) is a damn good idea with this sort of lift. Right - so I got one.
The one I got is offset, so the top plate is around 20mm offset from the plate that mounts to the diff. I had a play last night, and the only way I could get it to fit, so the ball joint lines up, is if the offset points towards the back of the car. Is this right?
Should I be undoing the shock mounts and attempting to 'roll' the diff back and have the offset point towards the front of the car?
Does this make sense?
Should I ditch the offset spacer and get a 'straight' spacer like B4V list, although they have no stock at the moment?
Thanks.
Post Posted: Fri Jan 11, 2013 7:16 am
I've got the offset one from oda offset to the front pretty much bolted straight on just had to slightly push up on the pinion to line it up
Post Posted: Fri Jan 11, 2013 10:48 am
Lifting causes the the diff pinion angle to roll backwards/up.
So fit spacer in a way to roll diff pinion forward/down
Sounds like you have it right way, in my opinion.
But loosening stuff makes them easier to line up
Post Posted: Fri Jan 11, 2013 3:14 pm
I think the ODA spacer only goes on one way not 100% sure but someone may be able to confirm that
Users browsing this forum: Google [Bot] and 15 guests
