Drop oil Take off wheel Undo handbrake cable from backing plate undo brake lines Remove drum to make the axle lighter undo the four nuts holding the backing plate to housing. Possibly fight to pull the axle out. Once axle is out you will see the seal
Users browsing this forum: Google [Bot] and 23 guests
