It is currently Fri Nov 06, 2026 2:01 pm
Vehicle: 95 sj70 and 78 lj81
Post Posted: Mon Jan 14, 2013 7:30 pm
I'm trying to work out my new brake set up for my LJ
The set up so far Vitara master, Sierra disc front and back, Sierra brake lines from the master to the sierra prop valve at the rear.
My problem is the Vitara has a dual outlet for the front brakes and single for the rear. The Sierra has a single outlet that splits at the chassis rail manifold. Can I just change the outlet on the Vitara master to a single?
Post Posted: Mon Jan 14, 2013 7:43 pm
I run a vitara master cylinder. I just plugged one of the ports
Post Posted: Mon Jan 14, 2013 7:49 pm
Is that on your sierra or LJ
Post Posted: Mon Jan 14, 2013 7:52 pm
Both and on my previous zook too
Post Posted: Mon Jan 14, 2013 8:08 pm
Thanks
I hope now this thing can get a move, the builds been pretty slow of late.
Post Posted: Tue Jan 15, 2013 5:53 pm
Next question
I have both Vitara (not vented) and Sierra front calipers I can use- are the Vitara units better or the same?
Users browsing this forum: Google [Bot] and 62 guests
