It is currently Fri Nov 06, 2026 11:27 am
Vehicle: New Grand Vitara
Post Posted: Wed Jan 23, 2013 5:10 pm
Hello All,
I have an 09 DDIS that has just run out of warranty, and of course something has let me down. I have taken the car to a Suzuki dealers workshop, as thay shpould look after a Suzuki customer properly.
An engine light came on the dash about 3 weeks ago ( a box with a fuzzy line) and the Mechanic said they had to replace two of the glow plugs, this did not fix the problem.
Now they have looked a bit deeper and now say it is the throttle body that has to be replaced.
At $2500 for the part, i get the feeling that they are having a lend of me.
Can anyone shed some light on possible spare parts or alternative parts from other cars.
Any information would be appriciated
cheers
Stuart Wilson
Vehicle: 02 XL-7
Post Posted: Wed Jan 23, 2013 5:51 pm
I'd be getting 2 maybe 3 opinions.
Thats sounds like garbage.
Post Posted: Wed Jan 23, 2013 5:57 pm
did they tell you what the codes were?
its a fairly common issue on modern diesels some times a good clean will sort them out
Post Posted: Wed Jan 23, 2013 7:59 pm
Is it the injection warning light?
Does it reset when you stop the car and then come on again after a little bit of driving, especially if you give it some throttle?
I've got a JB diesel and it was the Exhaust Temperature Sensor that failed just out of warranty. $1,085 for the part.
That's what was wrong with mine but I think the injection warning light is just a general engine warning light that could be caused by any of several faults.
double post
Post Posted: Wed Jan 23, 2013 8:16 pm
thats right about the light these units gum up with black diesel shit and become slow to react a good clean often helps
Post Posted: Thu Jan 24, 2013 7:57 am
I'm no expert, but does the computer need a reset, ie disconnect/reconnect battery, after any fixing gets done?
Users browsing this forum: No registered users and 39 guests
