It is currently Fri Nov 06, 2026 11:09 am
Post Posted: Tue Jan 15, 2013 4:59 pm
Hi all.
My vitara's G16B has been a little tempermental of late.
When cruising at low speeds it will sometimes just die ( 20km and lower), aswell as when im coming upto a red light and put the clutch in the revs will go straight to zero and she dies...
Other times it runs like a dream!
Is there a sensor that may be rooted and causing these problems?
lately its one thing after another and Im getting fed up!
Hope you guys can help, Thanks, Mark.
Vehicle: 91 WT 1.6EFI
Post Posted: Tue Jan 15, 2013 7:36 pm
Have a look at the ERG that was what was causing this in mine. I'm on my phone but ill hop on my computer and find the thread for you.
Post Posted: Tue Jan 15, 2013 7:40 pm
EGR?
Post Posted: Tue Jan 15, 2013 8:00 pm
ha ya I had a dyxlesic moment
Post Posted: Tue Jan 15, 2013 8:03 pm
here you go bud, my post is near the bottom. It fixed it for me and takes five minutes.
http://www.auszookers.com/forum/viewtop ... the+lights
Post Posted: Wed Jan 16, 2013 5:00 am
Cheers rossco! Will check it out and report back :)
Post Posted: Wed Jan 23, 2013 6:03 pm
Hi guys.. finally had a spare bit of time after work today so i decided to check out my egr..
I found one of the two bolts missing and the only bolt that was there was loose.
I cleaned out a small film/layer of carbon buildup from the egr ports and refitted.. car seems to stay at idle a bit better, but will occasionaly drop to the little line above 0 on the tacho.. about 300rpm? then creeps back up. is this normal?
Post Posted: Thu Jan 24, 2013 6:22 am
You need to clean the passageways back to the exhaust manifold and check the throttle body too.
Users browsing this forum: Google [Bot] and 23 guests
