It is currently Thu Nov 05, 2026 7:50 pm
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Feb 06, 2013 4:06 pm
Has anyone ever used the carb toyota 4age in a zook (hope i the carb 1 is called 4age still sorry if I'm wrong)
Post Posted: Wed Feb 06, 2013 4:55 pm
Nope: from Wiki (it was actually the listed example of how the codes work)
For Example
4A-GE
4 – 4th generation engine in the A engine family
A – The Engine Family it is in
G – Wide-angle dual camshaft
E – Electronically Fuel Injected
I wouldn't bother:
4A, 4A-C, 4A-L, 4A-LC
The basic 4A was a SOHC inline four (I4) 8-valve carburettor-equipped engine which produces 78-90 hp (58-67 kW) at 4800 rpm, torque: 85 lb·ft (115 N·m) at 2800 rpm. The power and torque output figures vary between different regions of the world.
North American market engines:
4A-C 1.6 L I4, 8-valve SOHC, 90 hp (67 kW) at 4800 rpm
European market engines:
4A-L 1.6 L, I4, 8-valve SOHC, 84 hp (63 kW) at 5600 rpm, and torque 96 lb·ft (130 N·m) at 3600 rpm (compression at 9.3:1)[9]
Australian market engines:
4A-C 1.6 L, I4, 8-valve SOHC, 78 hp (58 kW) at 4800 rpm
So it's really just (roughly) equivalent to a G16A. (In australian spec)
The real issue that scuttles it for me though is the gearbox. There's no desirable gearbox to use behind a 4A-C. You can put up with the annoying gearbox options if you have power to make the pain of back to back unis, crappy three speed autos and hydraulic clutches go away, but to have all those hassles and then have 58Kw just doesn't seem to make sense.
Just my 2C.
Post Posted: Wed Feb 06, 2013 5:02 pm
For Example
4A-GE
I wouldn't bother:
Just my 2C.
Thanks for ur 2c worth there is one around the corner I was looking at I was thinking about grabing it but I don't think its worth it even if it was free.
Thanks Steve
Post Posted: Wed Feb 06, 2013 5:13 pm
I know I bang on about this stuff incessantly :deadhorse: but it's not hard to find a 70-100Kw 4 cylinder motor, possibly even for free. The BIG hassle is the gearbox.
Post Posted: Wed Feb 06, 2013 6:00 pm
Na ur right.im not going to bother its just another shit box to get rid of.
Thanks for the wisdom
Vehicle: 85 ' Drover
Post Posted: Thu Feb 07, 2013 7:59 am
The 4age and 4ac share the same block. The toyota t50 gbox bolts to both of them. The 4ac is a great motor for how much you can get them for.
Post Posted: Thu Feb 07, 2013 8:47 am
isn't the T50 box is quite sought after & getting a bit rare these days?
Post Posted: Thu Feb 07, 2013 9:29 am
Yes, yes it is.
Post Posted: Thu Feb 07, 2013 9:44 am
There is a w series box that fits Wich don't quote me on it but I belive is out of a hilux
Post Posted: Thu Feb 07, 2013 10:29 am
You can buy them brand new from a place in NZ for $1,200
Post Posted: Thu Feb 07, 2013 10:32 am
that would be ideal for a tight arse sierra owner wanting to do an engine conversion on the cheap :lol:
Post Posted: Thu Feb 07, 2013 11:46 am
T50's arnt hard to get its just trying to find a good one. Fitting a w series box u have to buy an adapting bellhousing.
Post Posted: Thu Feb 07, 2013 11:53 am
The W box needs some mod's to fit.
There was many generations of the 4a block and a few variants. They are NOT all the same just to clear up another post above.
T50's are getting thin, partly from everyone converting k-sev's or sprinters. And they also need to be gently caressed or they pop..
Steve, have you looked into suitable gearboxes and worked backward from there?
Vehicle: 86 SJ413 dings / rust / 30's
Post Posted: Thu Feb 07, 2013 1:51 pm
I would say the aftermarket bell housing new in NZ would be $750 NZD tops, the 4age and 4/7afe i think are 2 really cool series of engines in my small world but the gearbox is the killer.
On the plus side you could possibly do away with the divorced transfer setup and run hilux transmission, its a slippery slope though
Post Posted: Thu Feb 07, 2013 4:30 pm
I should clarify, in terms of bolting a t50 gbox to a 4a series motor all block. s are the same in this respect. as far as im aware the only differences between the 4age blocks through all series is the 3 rib and later model 7 rib style. And also some had oil squirters on the pistons and others don't. But you can add oil squirters to a non oil squirter block (tap a hole in the oil galery). The outside physical dimensions of all blocks are all the same as far as I'm aware.
Note. Crank shaft bearing size changed too.
Post Posted: Thu Feb 07, 2013 4:40 pm
all very intersting stuff,i may 1 day consider a 4age one day
Post Posted: Thu Feb 07, 2013 4:50 pm
if you can find a cheap housing and t50 by all means its a viable conv, 7afe produces gd torque and reas revs from an 1800,but they are tall etc, anyone got any info on a GV G16 by any chance
Users browsing this forum: No registered users and 102 guests
