| Author |
Message |
magnat
Joined: Sat Jul 28, 2007 11:30 pm Posts: 1066 Location: Southern Highlands N
 Posted: Fri Mar 01, 2013 11:49 am |
What Globes do you recommend as an upgrade ?
I just looked now and I have Osram Bilux- 55w Globes in there now..
royce
 Posted: Fri Mar 01, 2013 12:00 pm |
Get a multimeter
Turn your high beam on (engine runnning doesnt matter easier with it off)
with the high beam on, measure the volatge at the battery terminals now get at the back of either headlight plug and with it still connected measure across the 2 vertical sockets
take measurement 2 from measurement 1 and report back with that number.
magnat
 Posted: Fri Mar 01, 2013 12:02 pm |
OK.. I will have to buy a multimetre first lol.. I will post back once this has been achieved.
ninjamoses
Joined: Mon Aug 13, 2007 11:30 pm Posts: 1787 Location: Butler, WA
 Posted: Fri Mar 01, 2013 12:11 pm |
Just for comparisons sake, my GV is 12.40V at the battery and 10.63V at the headlights (1.77 volt drop).
royce
 Posted: Fri Mar 01, 2013 12:44 pm |
ninjamoses wrote: Just for comparisons sake, my GV is 12.40V at the battery and 10.63V at the headlights (1.77 volt drop). Not for much longer
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Fri Mar 01, 2013 5:56 pm |
TheOtherLeft
Joined: Sun Aug 27, 2006 11:30 pm Posts: 818 Location: Sydney
 Posted: Sat Mar 02, 2013 4:21 pm |
After doing my own harness upgrade I recall I get 0.2V drop (this could also be the error in my multimeter). I used 8GA wire. Probably overkill but that's what I had on hand.
magnat
 Posted: Sun Mar 03, 2013 6:33 am |
Actually I installed a set of Narva Artic Plus 50 Globes, Cleaned the Headlight lenses with toothpaste and the results were a vast improvement.
fordem
 Posted: Sun Mar 03, 2013 11:34 pm |
Now rewire as suggested and see another vast improvement.
MacDaddy
Joined: Thu Mar 26, 2009 10:30 pm Posts: 10453 Location: Perth, Australia
Vehicle: Jeep
 Posted: Mon Mar 04, 2013 2:31 am |
magnat wrote: Actually I installed a set of Narva Artic Plus 50 Globes, Cleaned the Headlight lenses with toothpaste and the results were a vast improvement. I got the Narva Blue Plus 90 globes, so much more light, and a much nicer, whiter light...
magnat
 Posted: Mon Mar 04, 2013 7:38 am |
I was warned off going any higher then the 50 due to shorter globe life? Is it a load of crap or is there some truth in it ?
royce
 Posted: Mon Mar 04, 2013 9:55 am |
I had phillips version of a plus 100%, lasted months rather than years
atari4x4
 Posted: Mon Mar 04, 2013 10:05 am |
do a loom upgrade /end thread.
bakerboy
Joined: Sun Oct 25, 2009 10:30 pm Posts: 2291 Location: Perth
 Posted: Mon Mar 04, 2013 10:08 am |
I get around 8 - 12 months out of my narvas, and I have them on all the time when I drive.
TheOtherLeft
 Posted: Mon Mar 04, 2013 4:52 pm |
I had a pair of +90's when they were first released. They lasted 2 months.
bakerboy
 Posted: Mon Mar 04, 2013 5:05 pm |
Not sure why you are getting such short times :/
TheOtherLeft
 Posted: Mon Mar 04, 2013 5:08 pm |
Because they built to much finer tolerances and the wire used is much thinner, wound tighter so it is more fragile to vibration.
atari4x4
 Posted: Mon Mar 04, 2013 5:29 pm |
TheOtherLeft wrote: I had a pair of +90's when they were first released. They lasted 2 months. x2 i haven't had much luck with them either.
bakerboy
 Posted: Mon Mar 04, 2013 5:58 pm |
Ive run +100 before as well which is why I asked, bit hit and miss I guess
Mike57
Joined: Fri Jul 22, 2011 11:09 am Posts: 1009 Location: Melbourne
Vehicle: Suzuki Jimny 2009
 Posted: Mon Mar 04, 2013 8:49 pm |
As I think I have said in other threads the improvement you will get from a loom upgrade will be many times more than you get from any +50, +90 or + anything globes.
magnat
 Posted: Mon Mar 04, 2013 9:50 pm |
Yeah but a loom upgrade requires technical skills I severely lack..
Joe
 Posted: Mon Mar 04, 2013 10:06 pm |
magnat wrote: Yeah but a loom upgrade requires technical skills I severely lack.. Joe wrote:
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
MacDaddy
Vehicle: Jeep
 Posted: Tue Mar 05, 2013 2:34 am |
magnat wrote: I was warned off going any higher then the 50 due to shorter globe life? Is it a load of crap or is there some truth in it ? I have had mine in a year now, and no problems... from memory, on the actual package, they state they " dont " last as long as normal globes, but have min of how many thousand hours they last... so if yours didnt last very long, take them back, as i am pretty sure they have a 12month warranty...  Here is something to read, about headlight bulbs, from another forum... http://forums.whirlpool.net.au/archive/1582552
royce
 Posted: Tue Mar 05, 2013 6:47 am |
thats a terrible link with more bad opinions than this place lol the second bulb blows after the first cause all the extra current in the headlight circuit rushes to it higher voltage does shorten a bulbs life obviously and a dodgy alternator can blow bulbs, but not like they are talking about
Mike57
 Posted: Tue Mar 05, 2013 6:05 pm |
magnat wrote: Yeah but a loom upgrade requires technical skills I severely lack.. You don't need a lot of skill if Royce makes a loom for the XL7. It is plug and play. Failing that a small investment with an auto electrician will save you many hundreds of dollars in globes over the next few years.
