https://auszookers.com/forum/
death wobbles!!
https://auszookers.com/forum/viewtopic.php?f=5&t=3936
Author:  ZUK97 [ Wed Jan 28, 2009 1:55 am ]
Post subject:  death wobbles!!
Hi Guys,
Am new to this fine little 4by having just picked up a 97 coily [will post some pics ron].
had bad shudder come front wheel wobble/dance so put kits in both swivel hubs,this seemed to work, but for no particular reason it came back & went away again.
this is not just a slight shudder but one wher zuk has to come to a standstill to stop it.
my thoughts are maybe
*rims -wrong offset [i believe they are 15X7" vitara mags] although they have been freshly balanced
*suspension - maybe strut failure
any thoughts would be appreciated
regards Boxhead
Author:  lump_a_charcoal [ Wed Jan 28, 2009 2:01 am ]
Post subject:  Re: death wobbles!!
Wheel bearings or worn rod ends...
Author:  royce [ Wed Jan 28, 2009 2:02 am ]
make sure you set your swivel ebaring preload PROPERLY not jsut do up and wobble and go she'll be right
get a steering damper kit
replace the trailing arm bushes
cross fingers :)
Author:  something_else [ Wed Jan 28, 2009 2:10 am ]
check on the rims how much weight is on them.
2 of my vitara rims are warped and it takes 200 grams to even get it close to balanced.
Author:  hooki [ Thu Jan 29, 2009 7:32 am ]
would be a constant thing at certain speeds if it is wheel weights. I reckon rod ends.
Author:  Rockhopper [ Thu Jan 29, 2009 11:09 am ]
Funnily enough I had the exact same problem when I had the standard wheels and tyres on mine. I spent ages looking forthe problem but I could'nt find it. Problem was intermittant and happened at about 70km/h. I replaced the wheels and tyres with 31" tyres on 15 x 8 rims, replaced the springs and the shock absorbers all at the same time and the problem has disappeared never to be seen again. I suspect it might've been a crook shock.
Author:  kenn [ Thu Jan 29, 2009 10:37 pm ]
Had the same problem with my lifted Jimny years ago,it had Sierra offset rims which are a wider offset so i put a steering damper on it and towed it in 2 degrees ,fixed...So as Royce said..
