It is currently Thu Nov 05, 2026 2:58 pm
Vehicle: Suzuki
Post Posted: Mon Mar 04, 2013 12:04 pm
Just wondering best way to undo stripped filler plug on transfer case and its very tight or could I put oil in 4x4 stick hole I need help ASAP
Post Posted: Mon Mar 04, 2013 12:27 pm
fastest way is to weld a bolt to it. The heat helps unlock the thread, and gives you something to turn.
Otherwise, get a cold chisel and hammer and try to turn the plug. The shock loading can sometimes help free it up.
Post Posted: Mon Mar 04, 2013 12:51 pm
you can try semi lining up a slightly smaller socket (1mm size under or a close imperial size) and flog it on with a hammer and try that, or you can use a set of stilsons (adjustable pipe wrench) as that might be able to grip the roundness of it a bit better.
you and try grinding or filing a set of flats onto two sides and use those, or like old mate above mentioned weld another nut or piece of scrap to it and use that as leverage to turn it.
Vehicle: 2004 Jimny 1.6
Post Posted: Mon Mar 04, 2013 1:16 pm
I would weld. Hammering away can go horribly wrong
Post Posted: Mon Mar 04, 2013 3:12 pm
this may help :wink:
how to remove broken bolts part 1
or secret fitter trick #1
broken bolt on flywheel
place big washer on top of broken bolt
weld broken bolt to washer
use a pair of vice grips and unscrew broken bolt. weld a nut to the washer
and use a spanner if it is really stuck.
you beauty
Vehicle: 2012 jimny
Post Posted: Mon Mar 04, 2013 7:08 pm
bit of heat with a oxy can help too
Post Posted: Mon Mar 04, 2013 7:23 pm
Using a hammer and chisel is fraught with risk.
I had to change an entire rear axle housing, just before a trip,
because I christovered it :(
Post Posted: Mon Mar 04, 2013 8:12 pm
is that similar to shepping it :wink:
Post Posted: Mon Mar 04, 2013 8:18 pm
Yes, only with much more class :)
Post Posted: Mon Mar 04, 2013 8:20 pm
Thats a brave call.
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Mon Mar 04, 2013 8:21 pm
Lol when u say christovered it, sounds like some wizard jizz!
Vehicle: Suzuki
Post Posted: Mon Mar 04, 2013 10:02 pm
Ok thanks it is a flush bolt that uses the socket driver to undo it so I need t work out how to attach something without ruining it as I just put the transfer case in and was trying ti fill it with oil is their any way I can fill it through the shifter whole or something
Post Posted: Mon Mar 04, 2013 10:24 pm
It's a 10mm square drive, they get flooded out buy people using 3/8th ratchets & breaker bars.
You can remove the shifter & fill it that way.
Vehicle: Suzuki
Post Posted: Mon Mar 04, 2013 11:33 pm
I might be one of those people that use 3/8 driver woops and ok I will be doing that thank you
Post Posted: Mon Mar 04, 2013 11:44 pm
when you get it sorted & a new plug, do yourself a favour & buy some of these http://www.ebay.com.au/itm/TWO-PIECE-8M ... 1e77b506e8
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Mon Mar 04, 2013 11:57 pm
You can get a new plug from bunnings for about $1.70.
Just ask for a 1/2 inch bsp. Get the one with the slim 21mm flat head and you'll never have the problem again. :wink:
Katherine 2013!
Vehicle: Suzuki
Post Posted: Tue Mar 05, 2013 9:49 am
Thanks for the link Atari, I will have to get one and ihave 2 spare transfer cases so I have lots of plugs
Post Posted: Tue Mar 05, 2013 11:43 am
if you can get something with a lot sharper edges to it than a ratchet it will bite in a lot better
drilling a hole in it and sticking an easy out in also works really well if you have access to them, its not that they are tight its just hard to apply a lot of drive through them
Post Posted: Tue Mar 05, 2013 12:43 pm
buy a set of these... made by irwin tools. I undid my exhaust bolts with them. and they were a complete circle, no edges to speak of whatsoever.
cost about 40 bucks i think, handiest sockets i own.
bought mine from amazon
http://www.amazon.com/Irwin-Industrial- ... B0000CCXVZ
if you get them, be sure to get the "expansion set" also. makes the base set up to a set of 10 sockets.
MY BUILD THREAD HERE!!!!!
Post Posted: Tue Mar 05, 2013 12:59 pm
^^ How do you use them on a stripped filler plug??..
Users browsing this forum: Google [Bot] and 43 guests
