It is currently Thu Nov 05, 2026 3:12 am
Vehicle: Zook Monster Truck
Post Posted: Sat Mar 23, 2013 12:41 pm
I know a few patrol guys put a small air fitting into their distributer cap to "pressurize" the distributer to keep water out, around 3 or 4psi
has anyone done this on a G16B, will it work ok or stuff up the harmonics of the distributer??
or just put silicon around it to stop water getting in???
Post Posted: Sat Mar 23, 2013 12:44 pm
I dont think a whole lot of people bother, given the dissy is so high in the engine bay and the car starts floating before it gets that deep
Post Posted: Sat Mar 23, 2013 12:50 pm
haha, i like the way you think
Post Posted: Sat Mar 23, 2013 12:55 pm
Don't bother. If you are planning on doing some deep water crossings, get a latex glove, cut the finger tips off and chuck it over the dizzy with the leads coming out of the fingers. Tape it up, and its done.
For general duties, just spray it with some WD40 and call it done.
Post Posted: Sat Mar 23, 2013 1:36 pm
LJs have that setup from the factory. There's a hose from the heater box to the dizzy and bellhousing. The idea is you turn the heater fan on flat out and close the vents and it pumps air into the dizzy and belhousing(to keep water out of the clutch). I doubt the fan is powerful enough to actually do anything but it's a neat idea.
Of couse the flaw with that is the heater sucks its air from the vent on the cowl so once you get deeper than that water floods through everything.
My 1l Sierra had the fittings on the dizzy cap and bellhousing, I never checked the heater box though. If the cap from a 1l/LJ fits then you could use that instead of drilling and tapping the dizzy.
IMO it's not worth it anyway.
EDIT: Stupid touch screen phone, I accidentally hit submit!
In my 1l Sierra I did a lot of water crossings, a fair few over the bonnet deep. I never really had a major issue with the ignition system. I never did any prep at all, just drove in as is with crusty old leads and dizzy seal. I found you had to keep the revs down other wise it'd start dropping cylinders (fixed hub fan doesn't help). After it'd clear up and start firing on all cylinders again after 50-100m or there abouts.
The only time it conked out I timed a river crossing badly and hit the deep bit of the river (normally bonnet deep anyway) just as the wave from the previous car was coming back, it went up the windscreen and water poured through the air vents, it spluttered up to the bank before stalling and took about 30 seconds of cranking to fire back up. It's not unusual to have water dribble out of the heater box or air vents so don't sit your phone or whatever under them.
You'l start floating before you have issues with a Suzuki's Ignition system that's up to scratch, they're the best in the game in terms of water crossing ability. IMO If you fitted a viscous hub fan or thermo, had a fresh dizzy seal, new leads and the appropriate electrical grease in the right places you'd go just as well as a diesel.
The TB42s dizzy positioning is about as bad as you can get for a 4WD and Patrol owners seem to like just hitting everything flat out, hence their liking for siliconing the cap on and pressurizing the lot.
Fit diff and transfer breathers, you'l be amazed at how much water gets in there if you start regularly doing stuff like that. :oops:
Vehicle: LJ50V, SJ70
Post Posted: Sat Mar 23, 2013 1:38 pm
Or just keep some Blu-tac in the glovebox. Roll a long "spaghetti-shaped" piece and pack it around the outside of the Dizzy to Cap join line. The terminals for the Coil/Ign leads should be blind holes, and therefore waterproof.
Users browsing this forum: Google [Bot] and 381 guests
