It is currently Thu Nov 05, 2026 9:13 am
Vehicle: '94 suzuki maruti
Post Posted: Sun Mar 24, 2013 7:51 am
This sounds like a stupid question, even to me :oops: but I removed both the front and rear driveshafts, and i forgot to mark which way around they came out. the spline that allows it to expand and contract, do the shafts go back in with the male end facing the transfer and the female end facing the diff, or the other way around? hope that makes sense...
Post Posted: Sun Mar 24, 2013 8:10 am
Slip joint towards the transfer I thought.
Post Posted: Sun Mar 24, 2013 12:13 pm
It shouldn't matter. If you want to be picky slip joint up, only to hold grease in the spline, the downfall is that it holds mud also.
Post Posted: Sun Mar 24, 2013 12:35 pm
Yep, doesn't matter. I usually run the slip joint end towards the diffs
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 44 guests
