| rear sealed bearings https://auszookers.com/forum/viewtopic.php?f=5&t=39884 |
| Author: | Zuk_89 [ Wed Mar 27, 2013 3:47 pm ] |
| Post subject: | rear sealed bearings |
Anyone know or who can push sealed bearings on to vitara axle cheap ? Brisbane north are |
| Author: | tanshi [ Wed Mar 27, 2013 3:49 pm ] |
| Post subject: | Re: rear sealed bearings |
any one with a press. im located ipswich so might not be an option for ya |
| Author: | bumstein [ Wed Mar 27, 2013 4:12 pm ] |
I took mine to a local small mechanic.. He had it done pretty quick for 40 odd clams.. Prob only took him a minute to do, but he did get it done quick without having to book it in or anything |
| Author: | Ace [ Wed Mar 27, 2013 4:18 pm ] |
The bearing "can" be bashed on with some thick walled pipe, its the locking collar that goes behind it that as I understand it needs a little heat from a oxy / lpg plant / oven?? to chuck on behind it. Yes I have done some and used a press for the bearing (I havn't measured but must be a size for size or vfkn close) and the collar "must" be .01 under - have heated them up and "chucked" them on... |
| Author: | bumstein [ Wed Mar 27, 2013 4:27 pm ] |
viewtopic.php?t=8728 In this thread they've popped the axle in the freezer for a cpl days and lightly oven baked the bearings to put them on.. That's a cheap way!! Can't testify how effective it is, I haven't tried it |
| Author: | rick1970 [ Wed Mar 27, 2013 5:41 pm ] |
if at work , i will heat a block of steel with the oxy, sit shrink ring on this for a while, then fit.........with a bit of pipe (quicker and easier than using the press). If at home, bit of flat bar on the stove top, and put shrink ring on that, just takes a bit longer to heat....then do the same. |
| Author: | BlueSuzy [ Wed Mar 27, 2013 10:28 pm ] |
Grind them off, press them on Never had to heat/cool |
| Author: | Fatzook [ Wed Mar 27, 2013 10:35 pm ] |
BlueSuzy wrote: Grind them off, press them on Never had to heat/cool X2. PM'd. |
| Author: | rick1970 [ Thu Mar 28, 2013 10:15 pm ] |
BlueSuzy wrote: Grind them off, press them on Never had to heat/cool 99% of the time this is right. Had a problem with a mates 70's Celica yrs ago, supplied shrink rings moving......fitted cold and hot. Ended up taking a light cut on the axle and making 4140 rings with something like .006" interferance. Heat shrunk on......they didn't move. Tho very rare, and never seen it with a wheel brg, i have seen a bearing crack the inner race from cold fitting to a pump shaft. It was not seen on assembly and lasted maybe 5hrs before it, and the the pump destroyed itself......Sumitomo 7T excavator, big $$$$ repair bill. |
| Author: | Bugsta [ Fri Mar 29, 2013 11:10 am ] |
Had a hell of a time pressing mine on. Didn't help that the backing plate made it difficult to support it. |
| Author: | SierraDan [ Fri Mar 29, 2013 11:21 am ] |
Fatzook wrote: BlueSuzy wrote: Grind them off, press them on Never had to heat/cool X2. X3. |
