It is currently Thu Nov 05, 2026 10:51 pm
Vehicle: 2000 jimny
Post Posted: Tue Mar 19, 2013 6:05 pm
Has anyone else found that there is not much light in the back of the jimnys.
have noticed a spot to put a light in the back and was wondering if anyone has found an interior light to fit??
Vehicle: 2012 jimny
Post Posted: Tue Mar 19, 2013 7:18 pm
I have a rear interror light. Check out my build thread.
Post Posted: Tue Mar 19, 2013 8:11 pm
if that panel was designed for a "deluxe version" so they could have some more lights (but it never happened)... it should be a cable laying around there for it.... same way there is a speaker cable ready for some rear speakers that never happened
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Mar 19, 2013 8:22 pm
There's no wiring behind there
Vehicle: 2000 jimny
Post Posted: Wed Mar 20, 2013 12:40 am
i thought that there would be some sort of light off another car that might fit but. it doesn't seem so
Post Posted: Wed Mar 20, 2013 6:14 pm
Just checked my brothers EF fairmont. His rear door interior lights are 45x75, so it looks like it would be a good fit for that side panel but I reckon it will be a lot of effort for not much gain. Your best to do what jimny91 did and other people have done for rear interior light. Here's a picture anyway if you want to do it, they came out in the fairmonts side doors and ford wagons as a boot light.
Vehicle: 2000 jimny
Post Posted: Wed Mar 20, 2013 6:30 pm
thats exactly what i was looking for cheers heeps mate
Vehicle: 2004 Jimny 1.6
Post Posted: Wed Mar 20, 2013 6:46 pm
That's cool
Post Posted: Thu Mar 21, 2013 8:59 am
i put some cheap 3W Downlights in my jimny fitted nicely in the holes in the roof on the sides,
and was simple enough to run 2 cables around it.
creates heaps of light for the back
Vehicle: Jimny
Post Posted: Tue Mar 26, 2013 4:57 am
I have tryed the SX4 trunk lights, but they do not fit. I've found one that fits from an old Fiat car. It has a button, so i didn't integrate them with the door light. I've replaced the bulbs with a mini LED bar and it's f&%$# bright. Look at the last pic (just one side on). Also, it is not necessary to drill. Just use 3M double-face tape.
Post Posted: Thu Mar 28, 2013 9:30 pm
Just took these 5 minutes ago.
1. Replaced main bulb with LED
2. Installed Narva map light w/switch in centre of roof
3. Installed 'LED' brand LED strip light along back lip. With switch on RHS panel. Not that its a big issue, but I should have installed it on the left side!
The camera does not do it justice. Very useful amount of light...
Post Posted: Thu Mar 28, 2013 9:59 pm
Installation method for lights...
I put a square of Masonite above the map light to give the screw something to bite and I used rivets and washers to secure the rear light. I measured and drilled the cable hole accurately for both.
Users browsing this forum: fordem, Google Adsense [Bot] and 98 guests
