It is currently Wed Nov 04, 2026 4:33 pm
Vehicle: 1994 Suzuki Sierra 1.3
Post Posted: Wed Apr 10, 2013 6:22 pm
I've got a g13ba in my garage I'm pulling apart and I'm having
Trouble removing the crank shaft because I can't remove the crank
Pulley bolt at the front.
Any tips on how to get it out?
Post Posted: Wed Apr 10, 2013 6:27 pm
The outer pulley comes off by removing the 5 little bolts. Then you'll need an impact gun to undo the centre bolt. You may be able to somehow wedge a pry bar onto the flywheel and use a breaker bar on the crank nut but I don't like your chances
Post Posted: Wed Apr 10, 2013 9:45 pm
Possibly try and ratchet strap the engine down to a work bench and get a mate to help you. One on the flywheel as mentioned and one on the centre nut
Post Posted: Wed Apr 10, 2013 10:26 pm
Get one of these, best $80 I ever spent. I use it for anything and everything. Don't know how I lived without it.... Well slowly, painfully and with much swearing.
http://www.ebay.com.au/itm/240V-IMPACT- ... 114wt_1271
Vehicle: 92 Suzuki Sierra
Post Posted: Wed Apr 10, 2013 11:18 pm
reconnect your starter, there is a diagram in the factory service manual showing how to test the starter on the bench with jumper cables.. then do this
http://www.youtube.com/watch?v=Zybilegox1U
explained in length
http://www.youtube.com/watch?v=7G-adEVjfWI
have yet to do it on a suzuki but it worked on my sisters hyundai (engine spins same way) just bump the starter. I wish i had of known this a few years back when i was pulling apart a junk g13a. i had used a long tube and breaker bar and a block of wood inside jamming the crank.. even after all that it was not easy
Post Posted: Thu Apr 11, 2013 7:15 am
Had the same issue recently when replacing the head gasket. Used a blow torch to heat the nut then impact gun.
Sure it stuffed the seal behind it but this was replaced anyway.
Vehicle: Drover pickup turk
Post Posted: Thu Apr 11, 2013 7:57 am
Not having an impact gun, I used a length of flatbar drilled 2 holes closer to one edge for the bolts then used a file between the 2 holes so that I could get the socket on.
The ones on the right.
I like the tuna here
Users browsing this forum: Google [Bot] and 252 guests
