It is currently Wed Nov 04, 2026 4:44 pm
Vehicle: Suzuki jb43 jimny
Post Posted: Wed Apr 10, 2013 8:35 pm
Hey az I got some new head lights and I need to adjust them so there right, but ATM the drivers side isn't playing the game and wobbles when the same as the other side, am I doing somethig wrong, I have a 95vit if that helps, thanks in advance :peaceout:
Post Posted: Wed Apr 10, 2013 9:58 pm
have you got the headlights bolted down correctly?
should just be a case of adjusting the adjusters at the back of the headlights. what headlights are they, not the projector style ones?
Post Posted: Thu Apr 11, 2013 6:26 am
Is it bad if they are XD haha no I couldn't find a pair, there just the standard light that comes out factory :), what bolt should I be turning there's a long one that goes down an then there's a short on in the back, and I don't no what ones do what as the thing still wobbles. Could I maybe get them adjusted just don't no where to go, auto electrician ???
Post Posted: Thu Apr 11, 2013 7:23 am
If it wobbles there is something either loose or broken - remove the headlamp and examine it - and the two bolts to which you refer are the adjusters, one adjusts up/down and the other left/right.
Post Posted: Thu Apr 11, 2013 10:55 am
Must be loose cause it can be tightened and doesn't wobble but sits to low and isn't level. Ah ok so I just need to work out what one does what , where do u think I could go to get someone to do it properly if I wanted, auto electrician???
Vehicle: 95 Vitara Hardtop
Post Posted: Fri Apr 12, 2013 7:17 pm
I think maybe a panel beater/body repair shop would be the best option to adjust headlights, cos they have to do it after crash repairs (or should do).
Post Posted: Fri Apr 12, 2013 10:44 pm
I believe should is the correct word there.
Post Posted: Sat Apr 13, 2013 9:50 pm
Alright well atm trusty zip ties working a charm : D haha
Users browsing this forum: No registered users and 236 guests
