It is currently Tue Nov 03, 2026 8:20 am
Post Posted: Mon Sep 23, 2013 10:06 am
Hey guys, I've got a problem for the gearbox gods that i was hoping to get a little help with. I'm currently rebuilding a sierra gearbox for a mate but I've run into a little bit of a problem
I cant get this sleeve (flathead screwdriver is on it) off to pull apart the rest of the gear set. i cant just press from the bearing because there will be a little ball which sits in a little recess between the bearing and the sleeve which you can see in this photo i've found
and it would be very difficult to press from the spacer between the bearing and the sleeve because of the chamfered edge and the fact that there is very little room to pry from.
Any suggestions?
Vehicle: SWB Sierra
Post Posted: Mon Sep 23, 2013 11:28 am
Have you had a look at the FSM?
It says to press the washer and bush off first, then the bearing.
Post Posted: Mon Sep 23, 2013 12:13 pm
Yes you can, the ball bearing stops the washer from turning. Just press the washer (not bearing) off and the ball bearing will drop out.
Post Posted: Mon Sep 23, 2013 4:36 pm
Thanks guys ill figure out a way to press it off then. Where have you guys got your FSM from? each time i go to look for one i cant find any for free?
Vehicle: SWB Sierra
Post Posted: Mon Sep 23, 2013 4:42 pm
http://suzukiinfo.com/
Post Posted: Mon Sep 23, 2013 6:47 pm
use a bearing separator between the bearing and washer
Post Posted: Mon Sep 23, 2013 9:32 pm
X2 for the above two posts.
Users browsing this forum: No registered users and 525 guests
