It is currently Wed Nov 04, 2026 10:38 pm
Vehicle: 3 Door Grand Vitara
Post Posted: Thu Apr 18, 2013 5:41 am
Hi All :)
I just installed locker in my rear diff ...
But I was not sure if the original thrust washer and shims to sidegears still should be in the diff?
Post Posted: Thu Apr 18, 2013 12:56 pm
I've always left them in, in my sierra centres.
Post Posted: Thu Apr 18, 2013 5:07 pm
without them there may be extra play when you accel/back off and it can cause faster wear to the internal components.
Post Posted: Fri Apr 19, 2013 12:17 am
Thanks guys :)
I Will fit the diff in my axle and hope it works :)
Post Posted: Fri Apr 19, 2013 3:30 am
I took them out, as per the manual. It was pretty much perfect, quiet as and you don't feel it unlocking.
That was in a 1l/LJ diff.
Post Posted: Fri Apr 19, 2013 3:54 am
My manual don't say anything about the shims... But it says I should place the Thrust Washer?? Is this the thin "Belleville" (Cone washer)?? Or is the Thrust Washer the flat shims??
Post Posted: Fri Apr 19, 2013 5:55 pm
Just follow the instructions that came with the locker. Lockright says to keep the shims, Spartin says ditch them...
Users browsing this forum: No registered users and 213 guests
