It is currently Thu Nov 05, 2026 3:07 am
Vehicle: 1994 Suzuki Sierra 1.3
Post Posted: Fri Apr 19, 2013 10:12 pm
Want to put a bigger fuel tank on the Sierra.
Does anyone know any tanks other then the
Long ranger that bolts up or is close to bolting up?
Post Posted: Sat Apr 20, 2013 9:19 am
No, nothing other than the factory tank or a long range tank made for a sierra will bolt in. You'll have to move mounts or fabricate a tank.
Post Posted: Sat Apr 20, 2013 11:04 am
Does the car sag much at all with the long range tank?
Post Posted: Sat Apr 20, 2013 5:58 pm
Type in the search function '83L' and search author 'Fatzook' and you will see photos of a 83L EFI fuel tank from a Holden Jackaroo between the chassis rails of a 1L sierra trayback. He commented to say it fitted very well. Might be worth investigating further.
Vehicle: '94 suzuki maruti
Post Posted: Sat Apr 20, 2013 5:59 pm
does it sag much if you put one person in the back? the long ranger tanks are 70L for the SWB and 80L option for the LWB, vs the standard 40L tank. even with a full tank i doubt it would be more than 50kg over standard.
Post Posted: Sat Apr 20, 2013 6:15 pm
50KG= 110lb.
Stock rear springs are 150lb/", so 300lb would make the car "sag" 1". 110lb would make the car "sag" 9.4mm
Users browsing this forum: Google [Bot] and 219 guests
