It is currently Tue Nov 03, 2026 5:02 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2  Next
Post Posted: Fri Apr 26, 2013 2:13 pm
Has anyone used k&n oil filters? Any feed back
Looking at either knps1002 or knhp1002
Post Posted: Fri Apr 26, 2013 2:18 pm
dont bother.
its just wank factor, youll get better filtration from a disposable any day of the week. If you end up getting a snorkel grab a unifilter sock to help pre-clean when you bush-bash. thats more than enough
MY BUILD THREAD HERE!!!!!
Post Posted: Fri Apr 26, 2013 2:42 pm
Reading comprehension isn't your forte is it mate?
Vehicle: SWB Sierra
Post Posted: Fri Apr 26, 2013 2:43 pm
Do they require an increased service interval?
The ryco "performance" oil filters need to be changed every 5000km.
Post Posted: Fri Apr 26, 2013 2:44 pm
I'm tempted to run them, purely for the fact that they have a hex on them for easy removal.
Post Posted: Fri Apr 26, 2013 2:50 pm
How tight do you put them on anyway Tarzan? 8O
Vehicle: 85 ' Drover
Post Posted: Fri Apr 26, 2013 3:05 pm
I am highly skeptical of them based on their claims on the website.
You got the ordinary ones,
"Automotive Premium Wrench-Off Canister Oil Filters
Automotive Premium Canister Oil Filters
K&N Automotive Wrench-Off Canister Oil Filters
Oil Filters for Cars, Trucks, SUV and more!
K&N's premium wrench-off line of automotive and marine canister oil filters were developed to meet the high performance demands of race applications. They have rapidly become popular for their canister strength and durability. These canister style oil filters are designed to handle higher oil pressures than a standard oil filter and can be used with the latest synthetic motor oils. Most of these premium automotive and marine canister oil filters come with a 1 inch welded nut on the top that makes removal easy."
designed for higher oil pressure eh, lucky cause ive seen many oil filters explode due to not being able to hold the oil pressure..not!
Then you got the Pro series.
Pro Series Canister Automotive Oil Filters
K&N Pro Series Oil Filters have been specially designed for professional installers and service providers. Their high flow design can help to improve engine performance by reducing oil filter restriction. Our Pro Series Oil Filters have a fluted canister shape so they can be removed with a traditional oil filter wrench commonly available to commercial installers. These Pro Series oil filters provide outstanding filtration and engine protection throughout their service life. They are engineered to handle all grades of synthetic, conventional and blended motor oils. The pleated media provides high capacity making them suitable for extended oil change intervals when used in accordance with the vehicle and motor oil manufacturers recommendation. K&N Pro Series Oil Filters are available for canister and cartridge type oil filter applications.
High-Flow / Low Restriction Design
Rolled Threads
Fluted shape for traditional oil filter wrenches
Anti-drainback valves (where applicable) PSI relief valves (where applicable)
I'm cufused about the claim on "extended oil change intervals, but when used in accordance with vehicle and motor oil recomendation". So its ok for extended oil change intervals, but not if the vehicle sais it shouldn't be extended.
So when is it suitable for extended oil change interval? when the vehicle manufacturer doesnt specify an oil change interval?
I do like the nut on top of the oil filter, all oil filters should do this.
The rest? marketing BS.
How much more are they?
Post Posted: Fri Apr 26, 2013 3:08 pm
tight enough so they wont come off & i'll use a filter tool to make it easier to remove as i've usually got oily hands by that stage, it's in a bit of a shit spot on the H20a in a vitara... the engine bay isn't like a cock in a sock sierra style with room to swing a cat either side of the block. :wink:
Post Posted: Fri Apr 26, 2013 3:11 pm
Your to nice, its in a cunce of a spot on the 2.5 :lol:
Post Posted: Fri Apr 26, 2013 3:13 pm
I have seen a few filters blown off a motor by oil pressure. Some toyota motors have quite a rep for doing it.
The K&N filters are quite heavy compared to oe filters
Post Posted: Fri Apr 26, 2013 3:17 pm
blown off? (as in unscrewed themselves)
or the filter actually catastrophically fail (failure of the filter itself, while it is still attached)
Post Posted: Fri Apr 26, 2013 3:19 pm
Ends blowen out or the threads stripped as the filter gets blown out
Post Posted: Fri Apr 26, 2013 3:23 pm
I wonder if that is just a symptom of the oil pressure regulator sticking and forcing the oil pressure up.
Oil pump is a PD pump, so it will just keep on pumping against the closed regulator until something gives in. (ie, the filter)
Post Posted: Fri Apr 26, 2013 3:28 pm
The nut would be good for saving skinned knuckles in tight engine bays. :)
This is an interesting read. Obviously it's not for cars but it's interesting to see what the different manufacturers put in their filters.
http://motorcycleinfo.calsci.com/FilterStudy.html
Post Posted: Fri Apr 26, 2013 3:49 pm
ahhh shit, Just saw it then. sorry mate. Keep forgetting they make oil filters too, just saw k&n and immediately thought air filter.
I just woke up for night shift, ease up on me :wink:
Post Posted: Fri Apr 26, 2013 6:37 pm
Hey shep i just started using the hp1002.
Mainly because as the others have said the oil filter on the 2.5 gv is a real pain to get to. I have 2 types of oil filter wrenches and neither can work. Also the nut on the end will make life easier to take it off.
Only done about 3000 kays since i've put it on, and using castrol magnatec oil, on the dipstick the oil is still a nice goldy colour. Not sure if thats the filter or the oil though.
Post Posted: Thu May 02, 2013 7:36 pm
I decided that seeing as there is no decent info about oil filters out there I would buy a few different ones and then chop them up for a look after doing a oil change
So far I have the oe suzuki filter which I will change this weekend and will slap a k&n filter on
The black one cost $9.90 and the white one cost $19.90.
Anyway will update the thread whenever I do a oil change.
Post Posted: Thu May 02, 2013 7:42 pm
please use the NASCAR first & take it to the speedway track :peaceout:
Post Posted: Thu May 02, 2013 7:45 pm
If ball lets me onto the speedway track then ok. I am not a member any more so probably won't be allowed however.
Vehicle: Jimny '09 Manual
Post Posted: Tue May 07, 2013 7:53 pm
I used the for years on my Commodore. The unit itself is quite stong and I thought they were decent for the money or the money invested in the Commodore. Dunno if I would bother on my zook, either Genuine or Repco IMO is probably the best way to go.
Vehicle: 84 Suzuki Sierra
Post Posted: Fri May 10, 2013 5:40 pm
Just watch those black ones Shep, they don't work very well.... Particularly in the NT.
Vehicle: Sj70 tintop
Post Posted: Fri May 10, 2013 6:12 pm
lmao, i may have the wrong idea.... or i may not.
Vehicle: 92 Suzuki Sierra
Post Posted: Sat May 11, 2013 11:47 pm
http://www.300cforums.com/forums/genera ... ected.html
save you chopping it up i guesss...
Post Posted: Tue May 14, 2013 8:03 pm
Great comparison, I've never been picky about oil filters but will put more effort in next time around.
Thanks for sharing the link.
Post Posted: Tue May 14, 2013 8:31 pm
Are these for the Jimny Shep?
Post Posted: Tue May 14, 2013 9:10 pm
Yeah mate.
The Chrysler filter comparison isn't really relevant for us as I reckon you would be lucky to be able to buy 3 of the filters in that test. Plus those filters are for a seppo piece of crap and not a awesome car.
So far I have a silverline, suzuki, baldwin, ryco, repco, and the 2 K&Ns filters. Will cut them open when I have a bit of time.
Post Posted: Tue May 14, 2013 9:15 pm
From what I recall oil filters usually have a pressure relief valve in them which allows the oil to bypass the filter if it gets blocked, this is to prevent the engine from running dry. Its something to be considered if you run a high-pressure oil pump as you wouldn't want the oil filter to be permanently by-passed.
The two tests that I'd like to have seen done is how well do they filter? and at what pressure does the bypass valve open? the bypass valve may not be an issue with our engines as they run at relatively low pressures.
Post Posted: Wed May 15, 2013 6:57 am
Yeah mate.
I can't find a part number for Jimny, would you mind sharing please :)
I like this :wink:
Post Posted: Wed May 15, 2013 7:20 am
Yeah mate.
That's repco part numbers, drop the kn to get K&N part numbers. Hp1002 is the white one.
Post Posted: Wed May 15, 2013 12:17 pm
Thanks Shep, I thought that was just the range code.
I'm surprised at how long the list is of vehicles using the same filter.
Users browsing this forum: Google [Bot] and 433 guests
