It is currently Thu Nov 05, 2026 7:41 pm
Vehicle: 85.Ruf. rear air locker
Post Posted: Fri May 17, 2013 8:14 pm
I have a 1999 baleno 1.6 efi engine in my sierra
I cleaned down the engine as it was dirty now it's running on three cylinders
Buy the sounds of it
What I have tried to fix the problem
New coil packs
New leads
New spark plugs
Done a compression test and all cylinders are putting out the same
The only thing I came across when I unplugged one of the injectors it didn't change
The idle of the engine... But the other three did
Any one have any ideas
Post Posted: Fri May 17, 2013 8:54 pm
Water in spark plug area.
Plugs not connected right
Check Coil wiring plugs
Vehicle: Daisy
Post Posted: Fri May 17, 2013 10:00 pm
Have you got spark on that lead at all?
I can't think of anything else right now although if you definitely have spark on that cylinder and no firing then maybe the injector on that one is crook?
Too late/tired/pissed to be of more assistance right now.
Was it running properly at all?
EDIT: By crook I mean blocked/dirty/unplugged e.t.c. not just broken, check lots of stuff, think about what you need for it to be working and see which of those things is missing.
Post Posted: Fri May 17, 2013 10:17 pm
If you suspect an injector, try a bottle of injector cleaner in the tank.
Did you pressure wash it, maybe you blew off a wire somewhere.
Water problems often dry out themselves, but there are good dewatering products that don't short out electrics.
Post Posted: Sat May 18, 2013 3:20 am
If it was running fine prior to washing it then it's probably some water in a connection somewhere. You could let it dry out or blow some compressed air into the connections around the engine bay.
Post Posted: Sat May 18, 2013 6:00 am
It's has been a week since I washed it and
I've pulled the connections out And gave them a blow with air
Post Posted: Sat May 18, 2013 9:57 am
have you looked down spark plug ports?
Post Posted: Sat May 18, 2013 11:54 am
I've put new leads. Coil packs and plugs
After it started to play up
So they should be fine
Vehicle: Daisy
Post Posted: Sat May 18, 2013 3:55 pm
Fark I'm half pissed now but clearly that's better than tired and pissed from last night.
You would laugh but once upon a time my ex washed the engine of her car and then it wouldn't start next time she tried to start it, after checking a few things I pulled a plug to check for spark, hmm no spark, wait a minute, the freaking coil lead had popped off but not far enough to actually come off the coil...
Check everything meticulously one thing at a time and you will find the culprit.
Good luck and don't forget to let us know what it was!
EDIT: and when you say I've replaced this and that it should be fine, check a second time and have a really close look, you wouldn't be the first or the last to overlook something tiny like my example above because it looked ok on first visual inspection.
Post Posted: Sat May 18, 2013 5:15 pm
Going to take the front clip off tonight so I can see every thing
And go over everything twice i bet it will be somthing littlle like on wire or a loose conection
Post Posted: Mon May 20, 2013 9:22 pm
Well, if you plugged out 3 injectors and it affected the firing of the engine and 1 injector didn't, a check of that injectors wiring and failing that, replacing the injector would be a good place to start?
You could have blown a fuse somewhere as well so check all those as well.
Post Posted: Sun May 26, 2013 10:04 am
it ended up being a broken wire
Post Posted: Sun May 26, 2013 11:19 am
So you didn't check the wiring. :roll:
Post Posted: Sun May 26, 2013 3:20 pm
checked it after i found out it wasn't getting power to the injector
Users browsing this forum: No registered users and 182 guests
