It is currently Tue Oct 20, 2026 5:04 pm
lesspostingmorewheeling
Post Posted: Tue Feb 17, 2009 2:04 am
I've got a 110amp alternator in my sierra and i'm not really getting the benefits of it because i'm using a standard sized battery
what i was wondering was what are my options for running more than one battery?
i've got a few similar batteries that are still in good nick so i don't want to go out and just buy a bigger battery
i don't want some space shuttle computer system thing i just want something cheap and simple and easy to use
Mike
Post Posted: Tue Feb 17, 2009 2:07 am
you only need more batteries if you want to power more shit with teh engine off
you only more alternator if you want to power more shit that the old one could make :)
battery type depends on what you want to power and for how long, jsut having another battery in there for the sake of it is a waste of petrol
Post Posted: Tue Feb 17, 2009 2:14 am
i have lots of electrical bits and pieces and i don't want my battery the second i turn the engine off
also a bit of occasional winching might require a bit more power
Post Posted: Tue Feb 17, 2009 2:20 am
stick a cranking style battery in and hook everything to it, jsut dont use it with things that will run it flat all the time
Post Posted: Tue Feb 17, 2009 2:28 am
i'm just concerned that a winch and some spotlights will flatten my battery too quickly
Post Posted: Tue Feb 17, 2009 2:53 am
when do you winch and run lights with the engine off?
Post Posted: Tue Feb 17, 2009 3:18 am
not very often haha but at idle it doesn't charge very well so a bit of extra battery capacity would be nice
Post Posted: Tue Feb 17, 2009 3:24 am
Should be charging at least 13.4V @ idle. If it's not, check the fanbelt tension, and if that ok, replace the alternator.
Post Posted: Tue Feb 17, 2009 7:23 am
If your looking for back up power, to save money if you have electical stuff lying around. In my old zook I linked two batteries together with a switch to isolate the second battery when driving, and would switch second on to recharge when needed just mount on the other side on engine bay.
Great for camping never worry about going flat one for car and one for invertor . But might save you few bucks if you have everything already
Post Posted: Tue Feb 17, 2009 12:39 pm
I fitted mine here fits a full size truck battery to run my fridge easy
 Profile YIM
Post Posted: Wed Feb 18, 2009 1:07 am
just be carefull how close the battery sits to the exhaust. Id put in a heat shield if running such a big battery.
Post Posted: Wed Feb 18, 2009 1:49 am
how do i wire two batteries up? i either want to chage two similar batteries (both have the same cca rating) at the same time or i want to switch between 2 different batteries
Vehicle: LJ20 LJ50
Post Posted: Wed Feb 18, 2009 10:27 am
boat dual battery switch
They might coat a bit more but will switch between batteries and you can run either both or none all with the flick of a switch.
Imagine being able to turn on both for starting on this cold "I wish I was still in bed with my sister" tasmanian mornings or turning them both off as a theif deterant.
Camels have nice toes
Post Posted: Wed Feb 18, 2009 2:07 pm
CHECK SHEP'S LINK AT REPCO. YOU LOCAL MIGHT HAVE CHEAP DUAL BATTERY KIT. THESE ARE WORTH ABOUT $130.00
http://www.repcotrade.com.au/index.cfm? ... DB22B269C1
TRAVEL & TOURING POWERB 640402 WINCH- ELECTRIC HAND(USE GBW2000) $94.50 1 view
TRAVEL & TOURING MATSON MA98500 BATTERY-DUAL KIT (USE DBC100K) $62.40 1 view
TRAVEL & TOURING EVEREA E250A TORCH-BRIGHT LIGHT $2.50 6 view
TRAVEL & TOURING THULE BA 970-3AP ADAPTOR-BA 970-3 TOWBAR BIKE CARR $5.50 1
Vehicle: Zookless
Post Posted: Mon Aug 03, 2009 3:42 am
you only need more batteries if you want to power more shit with the engine off
battery type depends on what you want to power and for how long, just having another battery in there for the sake of it is a waste of petrol
So Royce, with a 110Amp alternator, would I even need to upgrade the battery to run a winch? I've only got the pissy little stock battery in there at the moment.
I'm thinking it would be a good idea anyway. I've got stereo, spotties, GPS, UHF, compressor and will have a winch. Some are used when the car isn't running (obviously the winch and spotties are not)
My car is also not run for extended periods quite regularly - 6 weeks or more. Would a sealed battery hold a charge better here? Like an optima or something?
Post Posted: Mon Aug 03, 2009 11:33 am
Winch will use more than the alternator can put out so a bigger battery would be useful
optima could be better, do you park near power? normal wet batteries with a Ctek charger might be cheaper and more flexible
Vehicle: Zookless
Post Posted: Mon Aug 03, 2009 2:29 pm
Yes I do park near power.
I have a cheap battery tender from Supercrap for my motorcycle. I could use this for the Zook, but I am paranoid about leaving it hooked up for 6 weeks while I am away. If I was at home to check on it every couple of days or so, I wouldn't mind.
I usually put the bike on charge the night I get home, so it's right to go the next day.
So far, the little stock battery in the Zook has held up well, but as I add more electrical stuff obviously it's getting more of a work out.
Vehicle: LWB Sierra & XL7
Post Posted: Mon Aug 03, 2009 6:14 pm
My old boy's Rodeo has a winch and spotties, but only a cheap 270cca S57 battery and seems to do just fine. In the commo that I recently sold, I could watch 2 DVD's with sub and amp going, and a spotlight (camping) for about 1 hour, again with a cheap S57 battery and still be able to start the car in the morning, I don't plan on running a fridge all night, So I was thinking of just putting in a larger decent quality battery. Other than keeping a set of jumper leads handy, It's cheaper than forking out for a dual battery kit + another battery.
BTW, the PULSE batteries available at Autobarns are quite good and very reasonably priced against Optima, I had one in my race car that use to sit for months without being started and it always worked.
'92 Vitara & Camper trailer
Users browsing this forum: No registered users and 181 guests
