Sorry for dumb question but do the 3 screws on the outer rim of a Coilys Brake Drum have to be removed before removing the drum itself,they are frozen in.I did a search and nothing relevant showed. ... TIA.
Joined: Wed May 05, 2010 11:50 am Posts: 823 Location: Beenleigh
Vehicle: Coil Sierra
Posted: Fri May 24, 2013 8:26 pm
No leave them. Hand brake off, put wheel back on and do nuts up halfway, make sure car is supported well and use the wheel as a slide hammer. If that fails do nuts up hand tight and undo the four nuts inside the 5 wheel nuts and pull the wheel away it should leave the drum stuck to the back of the rim. If that fails you may have to back the tensioner off. Not sure if you can do that from a hole on backing plate.
Users browsing this forum: No registered users and 115 guests
