https://auszookers.com/forum/
Help! Jimny ome lift, fulcrum bushes and 225s
https://auszookers.com/forum/viewtopic.php?f=5&t=41262
Author:  iambob [ Wed Jun 05, 2013 7:33 pm ]
Post subject:  Help! Jimny ome lift, fulcrum bushes and 225s
Hey everyone
Recently bought a 2012 jimny and have got a 40mm ome lift with superpro adjustable bushes..
Also have 225 70 15s on neg 23 offset 15x8s.
It's all in and looking right however my wheel aligner can't get It right. The tyres still scrub and the alignment can't even get close to manufacturer specs.
I've called everyone from suspension shops, 4x4 shops, fulcrum and arb... Know one has seen it before
Can anyone help me with what might be causing it?
Author:  atari4x4 [ Wed Jun 05, 2013 7:41 pm ]
Post subject:  Re: Help! Jimny ome lift, fulcrum bushes and 225s
what specs on the wheel alignment are out & where are the tyres "scrubbing"?
caster?
toe?
Author:  christover1 [ Wed Jun 05, 2013 7:43 pm ]
Any photos?
Is it towing in, towing out,
a caster or camber problem.
I don't know Jimnies, but those that do will need more info, to offer good advice
Author:  iambob [ Wed Jun 05, 2013 7:58 pm ]
Sorry for the lack of info, I know he's struggling to get out of negative caster
Unsure at this stage how the toe and camber are measuring up... I will try to get a hold of the measurements for this tomorrow
Also, tyres still scrubbing on front bar which I thought that wheel and tyre combo with the lift should clear.
Thanks for the speedy replies!
Author:  atari4x4 [ Wed Jun 05, 2013 8:01 pm ]
camber isn't adjustable on a live axle vehicle & caster should be in the positive range, not sure on the actual figure... a jimny owner will be able to answer that.
just wondering if the offset bushes been installed correctly?
Author:  sjzook [ Wed Jun 05, 2013 8:05 pm ]
-23 is still pretty decent offset, I ran -13 never had an issue
Author:  atari4x4 [ Wed Jun 05, 2013 8:08 pm ]
missed the -23 bit... that offset is going to cause scrubbing issues everywhere.
Author:  iambob [ Wed Jun 05, 2013 8:23 pm ]
New wheel aligner.... Problem solved Armsup
