| Author |
Message |
DAB
Vehicle: vitara
 Posted: Sun Jun 16, 2013 9:31 am |
ok. there is a whole heap of info on this site. and most is about sierras which brings me to the point. .. anyone got a suggestion guide on making a winch bar and where to attach to a shorty vitara?
maybe ive been missing it reading through the threads but there are a hell of alot of them
tassie jeeper
Vehicle: 1995 2.0V6 Vitara LWB
 Posted: Sun Jun 16, 2013 4:52 pm |
step 1: remove front bumper. step 2: create a mounting cradle for your winch. step 3: "u may need help with this one" hold the winch and cradle up under your grill and take measurements for the chassis mounting plates. step 4: add the chassis plates to the winch cradle and fit it to the car. step 5: bend up a piece of 50mm pipe 3mm wall to fit around the lower part of your grill and back to your wheel arches and fix it to the cradle. step 6: take another piece of pipe can be 50mm again or a bit smaller 40mm (depending on what u think looks right) and make a piece that from your headlight to down below your winch cradle across underneath it and back up the other side. step 7: make a support bracket from where the front wish bones are mounted to the lower pipe on bull bar and plate it in this will act like a skid plate. step 8: remove bull bar finish all welds off and tidy for aesthetics then take it to your local powder-coater.
if you have experience with a welder and are mechanically minded you should be able to accomplish this in a weekend. best of luck with it and post photos.
tassie jeeper
 Posted: Sun Jun 16, 2013 5:03 pm |
Last edited by tassie jeeper on Sun Jun 16, 2013 11:12 pm, edited 1 time in total.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Sun Jun 16, 2013 6:55 pm |
tassie jeeper
 Posted: Sun Jun 16, 2013 8:55 pm |
Quote: Gwagensteve thanks for fixing that for me. i do not have a photo sharing account on any pages. can u show me how to link photos like above with URL? that might make everyone elses life a bit easier.
atari4x4
 Posted: Sun Jun 16, 2013 8:59 pm |
hit the [IMG] button when you go to the full editor/reply screen then paste the link in between.
tassie jeeper
 Posted: Sun Jun 16, 2013 11:07 pm |
shandy92
Joined: Tue Nov 25, 2008 10:30 pm Posts: 5066 Location: perth, Australia
 Posted: Sun Jun 16, 2013 11:25 pm |
while the topic is current, any one got any good pics of some decent mounts? There is virtually nothing on the front of the swb chassis to have a good solid mount. Unless you incorporate some U-bolts around the crossmember.
Joe- you would have seen/made something for a swb vit in your time? would you be able to shed some light on these please.
Thanks Mitch
tassie jeeper
 Posted: Mon Jun 17, 2013 12:55 am |
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Mon Jun 17, 2013 4:19 am |
Try something like balls sierra mounts in the good tech there isn't anything strong on any suzuki chassis
got_bar_work
 Posted: Mon Jun 17, 2013 4:24 am |
How bad would air flow be having the winch up in the grill?
tassie jeeper
 Posted: Mon Jun 17, 2013 10:33 am |
got_bar_work wrote: How bad would air flow be having the winch up in the grill? personally i wouldn't do it with standard radiator but i havent had my zook long enough to know what the radiator is capable of.
DarkHorse
 Posted: Mon Jun 17, 2013 8:10 pm |
I'd hazard a guess that most of us block a good percentage of our grilles with lights and other crap without any negative effects.
I seem to recall reading that significantly more air gets to the radiator from beneath anyway... but I can't remember where or how I came across that...
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Mon Jun 17, 2013 8:15 pm |
MOAR!!
_________________ mlm
DAB
Vehicle: vitara
 Posted: Mon Jun 17, 2013 9:45 pm |
cant believe how well the question got answered. by the sounds of thing meny people was after a little inspiration. thanks all. when I get round to making mine ill try to document a detailed step by step for others to follow and improve on
