It is currently Tue Nov 03, 2026 8:07 pm
Vehicle: TwinCab Sammy
Post Posted: Tue Jun 18, 2013 5:05 am
Hi guys!
Do you think a gti engine can handle 31/10.5/15 tyres with a 4.16 t-case?Wont be long enough to spin them right from low rpms?
Maybe should i get some ring and pinions?
Thank you.
Post Posted: Tue Jun 18, 2013 8:24 am
I'd be going 4.9 or 5.14 transfer gears before messing with the R&P's.
Post Posted: Tue Jun 18, 2013 8:34 am
Same here.
Post Posted: Tue Jun 18, 2013 12:05 pm
Wouldn't that depend on the application, transfer gears are mainly low range, meaning good low range, but still crap in high range, R&P do both ?
Post Posted: Tue Jun 18, 2013 12:07 pm
sierra transfer gears do both high & low range
Post Posted: Tue Jun 18, 2013 12:14 pm
im chasing lowering my gears, but thought like say 180% low range reduction, and 20% high range sort of stuff.
I have a set of 5.12rnp but thinking 4.6 would be better, so not sure now.
Post Posted: Tue Jun 18, 2013 12:18 pm
3.7 down to 5.12 is only 27% ish
so transfer gears would do the same job
Post Posted: Tue Jun 18, 2013 12:30 pm
I very seldom use low range, was thinking too low.
But I spoz you do not need to use 1st low hey, select 3rd or 4th, whatever needed.
Post Posted: Tue Jun 18, 2013 8:26 pm
Well lets look at it another way.
Unless you have the skills/ equipment to set up your diffs for the R&P change, you'll be lucky to pay less that $500 PER DIFF CENTRE!! for bearings and lapping. (more like $650ea)
A transfer gear set will give you similar reduction, and can be done at home with some feeler gauges and no special tooling at all. The instructions are also comprehensive.
Post Posted: Tue Jun 18, 2013 8:35 pm
Yea I know mate, but im going to add ARB airlockers front and rear, havent asked yet, but told they will put the RnP change in for the same price.
I have zero possibility of doing RnP, so its off to the diff shop.
Post Posted: Tue Jun 18, 2013 8:51 pm
I SERIOUSLY doubt that. Get a written warranty too!
Post Posted: Tue Jun 18, 2013 8:57 pm
bugger, I read it here somewhere that an ARB install was done and RnP changed same price.
hmm, may be a lot more than I factored in then, maybe gears to start.
Have the RnPs, got a spare transfer, may have to go that route then.
Post Posted: Tue Jun 18, 2013 9:00 pm
x12
Post Posted: Wed Jun 19, 2013 5:00 am
Ok i'm going with the tcase.thanks
Users browsing this forum: Google [Bot] and 109 guests
