It is currently Sun Oct 18, 2026 11:03 am
Vehicle: 75 Cruiser
Post Posted: Mon Jun 19, 2006 10:59 am
here's the first carby question :lol:
How much would it cost to redo/recondition/rebuild/whateveryoucallit the carby?
Is it worth trying to do it myself, or pay $400 or what ever it costs to get someone like Carbtech to do it?
Post Posted: Mon Jun 19, 2006 12:53 pm
sierra carbs dont have any specific vacuum, pre load or gap settings that need special stuff to set, so unless the throttle spindles are worn and have free play or the choke chamber is shot I dont see any need to pay to get it done
BUT
there is a reason it costs so much to do a carby, its a lot of fiddly work and cleaning, all you are doing really is pulling it apart cleaning all the crud out and putting it back together, if you dont get it super clean or put it back together properly it will still be crappy
dont always blame the carby either, poor spark, stuck dizzy weights, wrong plug gap all has an effect, mine has a bit more power and uses less fuel just from fitting a hotter thermostat, even though the choke was turning off before so should of not really made a difference
Vehicle: 75 Cruiser
Post Posted: Mon Jun 19, 2006 1:26 pm
ok, welp, i think i need to do something... coz you keep catching up to me on the road :(
Post Posted: Mon Jun 19, 2006 1:58 pm
thats cause I have a powerhouse :wink:
and I'm not scared of sitting full throttle at 5500rpm to catch up to people :oops:
Post Posted: Mon Jun 19, 2006 10:31 pm
Hey Steve what do you think Your Carb is Doing?
Is it too rich or lean?
If you rev the .... out of the car and then take your foot off the throttle does it continue to speed up??? (if it does its rich)
Try and work out if its running rich or lean or even OK.
Might help work out if U need a rebuild or look in another area eg Ignition timing
Vehicle: 75 Cruiser
Post Posted: Tue Jun 20, 2006 12:07 am
seems to have a lack of power sometimes, like when going up a hill on the highway.
and uses a fair bit of fuel.
Royces 1.3L seems to have more than mine :(
Post Posted: Tue Jun 20, 2006 12:47 am
mines uses heaps of fuel, and I revvv the rinnger out of it to keep up
what thermostat do you have? what temp does it run at?
Vehicle: 75 Cruiser
Post Posted: Tue Jun 20, 2006 1:21 am
the temp gauge sits really low.
dunno about the thermostat.
Apparently the auto choke thing was jammed on a while ago and it was running really rough, but my cousin (gary) disconnected the choke which fixed that.
I don't flog it at all, maybe that's the problem :lol:
It's not that important, but would be good to sort out eventually, would be good to reduce the amount of fuel consumption for some future long distance trips.
Post Posted: Tue Jun 20, 2006 1:28 am
reason I ask is my choke worked fine, was all set properly but after putting the proper thermostat in I find it has a bit more go on the highway and uses a little less fuel, my guage sits just under the little temp symbol now, so not quite halfway, before was about 3mm off cold
Vehicle: 75 Cruiser
Post Posted: Tue Jun 20, 2006 10:54 am
yeah mine sits about a couple mil off cold.
I didn't know you could get different thermostats!
Post Posted: Tue Jun 20, 2006 11:20 am
yeah all sorts!!!!!!!!!!!!!!
get the proper 92 degree one and try, if your radiator isnt up to scratch it will overheat easier though
Post Posted: Sat Jul 08, 2006 7:24 pm
Went and got mine done a recarb at Kawana, dave there was a cabinet maker and is self taught and he had the carb problem sorted in quick time
Plumming was wrong He said that is why it was using a lot of fuel 15lt per 100k
Power Boster was not working REPLACED with S/H
Choke was not working
Mixtures were to rich
Float was to high
New Needle and seat
Cost $130
well worth the money she runs like a sewing machine
Steve W
Vehicle: 75 Cruiser
Post Posted: Sun Jul 09, 2006 9:19 pm
sounds like my issues hugo :?
Post Posted: Tue Jul 11, 2006 12:11 am
We stll talking car issues?
Plumming was wrong
Float was to high
New Needle and seat
Sounds like the girls i used to date.......... :oops:
Vehicle: 75 Cruiser
Post Posted: Tue Jul 11, 2006 11:14 am
i don't think anyone is game to touch that one sneaky :lol:
Post Posted: Thu Sep 14, 2006 5:18 pm
OK steal of thread time.....
SJ413 1.3 LWB carb problem
engine "bogs down" just above idle... but runs fine at top end
rebuilt carb w/carb kit ....
redone intake manifold gasket
idles more smoothly now but still have the same problem....
any ideas ? could it be the fuel pump ?
" It's 'cause theres to many rabbits in china ! "
Post Posted: Thu Sep 14, 2006 8:46 pm
There are several small hoses running around the carb mostly to do with pollution control & such. Often the problem you mention occurs when these become cracked or blocked.
Sometimes blocking said hoses also has the desired effect.
For me, carbies are a job I leave to the pros.
Post Posted: Thu Sep 14, 2006 8:59 pm
yeah they are all clean .... my mate is a arb mechanic ! :D and its got him stuffed too !
Post Posted: Thu Sep 14, 2006 9:13 pm
Then there is always the fact that zooks are temperamental little so and so's that don't alway do what they are meant to do.
I've had similar probs over the years with 1.3's and even though everything seems to be right they just don't play. Even to the point of swapping the carby over and still having the problem.
There are a lot of smart people that come to this site, hopefully they will have a suggestion.
Post Posted: Thu Sep 14, 2006 10:06 pm
my brother had a similar problem with his.
our machanic cleaned out the choke line there was water and crud in there after he blew all the stuff out it rang heaps better.
ask sambo exactly what was done
josh
Post Posted: Thu Sep 14, 2006 10:10 pm
tah dude .... SAMBO !!!! ?????
Post Posted: Sat Sep 16, 2006 5:04 pm
A bog down from idle is normally the idle mixture is to lean or the accelerator pump isnt right, did you get the ball and spring in the bottom of it right?
Users browsing this forum: Google [Bot] and 317 guests
