It is currently Wed Nov 04, 2026 9:06 am
Post Posted: Mon Jul 22, 2013 4:59 pm
Where does the G16B stop and the G16BB start in swifts, Balenos and Vits? And whats the primary differences?
When does the Coil packs come in, for same? Or do the coil packs make the extra B?
What version makes for a simple swap into Sierra, Vitara and Jimny Mk1?
How much work is there for other conversions for same?
I think I am right that the G16BB with coil packs is a simple swap for the Jimy Mk1?
Please learn me.
Lastly, what is the most sort after G16x?
Post Posted: Mon Jul 22, 2013 7:23 pm
I've never heard of a g16b referred to as a g16bb. The g16 vitaras never got coil packs, baleno's did after 1998ish (there's 2 types coil packs either on back or the top of the head), g16 GV's all had coil packs and are the best donor and are probably the closest to the g13bb found in the jimny, they're hard to find though.
I believe its common to swap the jimny head and manifolds onto the g16 block and then you don't need to worry about anything else.
Post Posted: Mon Jul 22, 2013 7:50 pm
Well no BB version would make things easier if there is no BB. I have seen it referenced a couple of times, but would like to find out for sure.
Post Posted: Mon Jul 22, 2013 10:37 pm
Well I can assure you there is no such thing as a G16BB. Only a G16A 8v carby, G16A 8v TBI, G16A MPFI, G16B MPFI, G16B coilpack MPFI.
Post Posted: Tue Jul 23, 2013 5:45 am
I reckon the closest you could get to a real G16BB would be a G16B block with a G133BB head on it which is essentially identical to a G16B head anyway.
Post Posted: Tue Jul 23, 2013 6:34 pm
Ok, that's probably what they are referring to. Good to know.
Post Posted: Wed Jul 24, 2013 1:30 am
The heads are identical! Not sure what makes it a BB tho...
Post Posted: Wed Jul 24, 2013 1:25 pm
Imagination :wink:
Users browsing this forum: No registered users and 423 guests
