It is currently Tue Nov 03, 2026 5:02 pm
Vehicle: SJ51T
Post Posted: Wed Jul 24, 2013 5:53 pm
...without undoing the torq screw ? because I don't have the tool
I'm trying to remove the cluster so I can play around with the VSS but the hazard light switch is in my way.
Vehicle: 92 tintop sierra
Post Posted: Wed Jul 24, 2013 5:54 pm
A big flat head screw driver worked for me
Post Posted: Wed Jul 24, 2013 5:56 pm
just pull up on the shroud and remove then a bit of force and cluster should come out
Post Posted: Wed Jul 24, 2013 6:17 pm
Vice grip steering wheels are all the rage :lol:
Post Posted: Wed Jul 24, 2013 7:45 pm
If you can't loosen the bolts holding the steering column then try loosening off the bolts that hold the dash down
Vehicle: SWB Sierra
Post Posted: Wed Jul 24, 2013 8:11 pm
Is your car at your place or work?
If its at work I can swing past sometime tomorrow afternoon and undo them.
Post Posted: Wed Jul 24, 2013 10:36 pm
Drop the bolts that hold column to crossmember, it should drop far enough to give dash clearances (If its same as my vit)
Vehicle: ***
Post Posted: Thu Jul 25, 2013 2:55 am
undo the two bolts on top and give it a GOOD pull.
Vehicle: LJ50V, SJ70
Post Posted: Thu Jul 25, 2013 6:03 am
Or just buy the right tool!
(BTW the Calamari ring on the gearstick is past it's useby date. Throw it out.)
Post Posted: Thu Jul 25, 2013 7:20 am
Let's keep it clean shall we? :rofl:
Yeah, as 303zuke says, buy the right Torx bit from a bolt supplier
Post Posted: Thu Jul 25, 2013 11:04 am
Those bolts on the bottom of the column that are torx usually have a big flat head slot in them. That's how I've gotten them undone previously.
Vehicle: '94 suzuki maruti
Post Posted: Thu Jul 25, 2013 5:15 pm
i've removed my cluster a few times and never had to undo that... just a bit of "gentle" persuasion and it does get over that switch.
Post Posted: Thu Jul 25, 2013 10:48 pm
You can find a allen key that will fit in the torx head bolt. Then when you get them out, use a hacksaw to put a slot across the top for a flat head screwdriver, or replace the bolts with something else.
Vehicle: SWB Sierra
Post Posted: Fri Jul 26, 2013 12:52 am
It should be all sorted by now.
Post Posted: Sun Jul 28, 2013 10:50 pm
Um the the bolts on the column it will drop it down enough to pull the cluster out
Users browsing this forum: Google [Bot] and 438 guests
