It is currently Tue Nov 03, 2026 9:38 pm
Vehicle: 1995 Sierra
Post Posted: Fri Jul 26, 2013 3:08 pm
gday guys, im new here and search wont work on my phone, im probably doing the proverbial :deadhorse:
im installing 4:1 gears into my transfer case, with unlocked diffs and small tyres,
does anyone think its worth spending money on a transfer cradle or is this mild enough to suffice for the normal mounts?
also do you need a press to remove the bearings or can you just use a puller?
thanks! :rambo: im new and annoying!
Post Posted: Fri Jul 26, 2013 6:07 pm
I ran 4.16 and bent the long side mount. Reinforced with some scrap steel im still using it. Its been used with 4.16, 5.14 and 6.5.
I recommend a press and puller.
Post Posted: Sat Jul 27, 2013 2:15 pm
ok thanks, so the mount wasnt replaced, just welded/reinforced? i might try running it as is, if it bends ill reinforce it.
hopefully a bearing puller and some improvistation will work haha.
Users browsing this forum: No registered users and 88 guests
