It is currently Wed Nov 04, 2026 12:03 pm
Post Posted: Thu Aug 08, 2013 9:02 pm
Ive had my 96 vit for a few months now and Im not sure whats up with the water level in the radiator.
The first time I checked the overflow bottle the suction pipe had fallen off but even with the pipe back on the overflow bottle is always empty and the water in the radiator is below the top of the cores.
The oil is good the water is good and there is no steam out the exhaust.
It only ever gets to half way on the temp gauge even with a day of wheeling.
Any thoughts on where to start? Could the radiator cap be faulty and upsetting the flow between the radiator and overflow bottle?
Thanks Nik
Vehicle: 1997 vit 1.6 16v
Post Posted: Thu Aug 08, 2013 9:33 pm
same thing was happening to me, turned out there was a crack in the block underneath the intake manifold. im not saying its the same for you but its some thing to look out for.
Post Posted: Thu Aug 08, 2013 9:36 pm
Have you been topping it up? Stick some green concentrate in as it makes a easy to see stain if there is a leak. Plus it should have green in it anyway
Post Posted: Thu Aug 08, 2013 10:06 pm
I have checked for cracks in the block as Ive seen that before but I will look harder. The water is still green the only thin I can see is what looks like a small oil leak out of the front of the motor not sure if its the crank seal as its to the side of the timing belt cover.
Nik
Post Posted: Thu Aug 08, 2013 11:37 pm
Sounds like the water pump is leaking if you have a leak from the front near the timing cover. How often are u toping it up?
Post Posted: Fri Aug 09, 2013 8:07 am
Take it to a radiator specialist and have them do a pressure test on the cooling system.
Done quickly and painlessly
Post Posted: Fri Aug 09, 2013 11:31 am
The last few days Ive had to top it up everyday. Not alot but still it shouldnt be happening.
I havnt had a the cover off a EFI motor is it any harder to change the water pump?
Post Posted: Fri Aug 09, 2013 2:10 pm
How old is the radiator cap? Why don't you replace that first and see what happens?
Post Posted: Fri Aug 09, 2013 2:13 pm
mate, with the engine running jump under and have a look at a little hole in the under side of the water pump. If you have water coming from here (water pump weep hole) then you can be 100% sure that its life has come to an end and is due to be replaced.
if its not leaking from here then the water pump is fine. check the rad cap
Post Posted: Fri Aug 09, 2013 6:59 pm
I was thinking along the lines of what you guys had suggested. But I went to see a retired mechanic today, nothing like an old timers common sense to make you feel like a noob. Explained the symptoms to him he walked up grabbed the top and bottom radiater hoses and said theres your problem the thermostat isnt opening. Took it out and punched out the middle for now and its all good!
Post Posted: Fri Aug 09, 2013 10:08 pm
Nik wrote:
...... I can see is what looks like a small oil leak out of the front of the motor ......
thermostat wouldnt cause a leak tho?
have you looked at that water pump?
Vehicle: 92 Suzuki Sierra
Post Posted: Fri Aug 09, 2013 10:31 pm
where is the needle sitting on the temp gauge? My friends lwb would sit just bellow half, and she was putting a litre or more a fortnight. Told her it should be n higher than a quarter and she said it always sat there. She had to get a new radiator to pass a blue slip for act-> nsw rego. Put the radiator in with new cap, needle stays at 1/4 mark and water level has been good for over 3 months.
In anycase i'd strongly recmmend you by a new thermostat rather than just have a hole in the old one. Thermostats are there for a reason a fact which takes me alot of energy to explain to self-taugh backyard spanner monkeys in my life.
Post Posted: Fri Aug 09, 2013 11:32 pm
LoL at old mechanic
My jimny uses the overflow bottle every tank of fuel.
Blown headgasket/cracked head! Typical g16b pos motors
Post Posted: Sat Aug 10, 2013 8:02 am
There will be a new thermostat coming Thats why we put oart of it back in to try to restrict the flow a little while I wait fo the new one.
I think it was getting hotter than the gauge said so knowing that it was a long trip home with lots of stops and the heater on full to help it cool down . So I assume it was pushing the water out the overflow. Weird thing was it didnt show any other signs of running hot, it idled and ran smooth.
Post Posted: Sat Aug 10, 2013 8:52 am
Can you smell coolant constantly?
Is the overflow bottle full when driving? Or just after a decent drive??
If its getting hot enough to push out that volume of water, you will smell it (hot motor + coolant) and its probably cracked the head
Sorry to be that person but that's my experience with these motors.
Post Posted: Sat Aug 10, 2013 10:08 am
such a distinct smell, my TB42 pootrol has scared me for life... i can smell even the slightest coolant leak now. :(
Post Posted: Sat Aug 10, 2013 10:13 am
same for my friend vit LWB, hopefully its the radiator not the head for you
Post Posted: Fri Aug 16, 2013 7:45 pm
Just an update after I replaced the thermostat Ive been driving it all week checking the oil and water daily and its all sweet so far.
Users browsing this forum: Google [Bot] and 94 guests
