It is currently Wed Nov 04, 2026 3:16 am
Vehicle: 99 Grand Vitara
Post Posted: Thu Aug 08, 2013 12:42 pm
Think it's time to upgrade my CVs to lux ones. Sucks breaking a CV everytime im out. Anyone know who does kits for them in Aus pref Brissy?
And what's required to fit them?
I know joeblow is going to be making stronger cvs soon but i think that'll be later this yr/next yr
http://www.strictly4x4.com.au
Vehicle: 96 LWB Vit, 2.5L powerhouse
Post Posted: Thu Aug 08, 2013 3:31 pm
If I were u I would do as much research as you can so you know yourself what needs to be done. Get all the parts together and rock up at petes house with a hand full of cash and a whip.
From what I can tell its just one machining part that's holding him up so if you can help him solve that you just might get the first set!!
Post Posted: Thu Aug 08, 2013 5:40 pm
Wat happened to the set that came off the comp vit from camberra
who bought them . we might be able to get a look at them to copy the parts
there is a brass bush
a round plate with some holes in it to adapt the vit flange to toy cv
and the lock out spacer has counter sunk holes to go on the hub and then taped holes to bolt the toy lock out to
i think thats it
Post Posted: Thu Aug 08, 2013 5:47 pm
plenty of info in this thread viewtopic.php?f=4&t=18996&hilit=hilux+CV&start=60
Post Posted: Thu Aug 08, 2013 5:58 pm
Dads mate could possibly CNC machine something up at work.
i think thats it
No clue 8O
Cheers will have a look now.
Post Posted: Fri Aug 16, 2013 6:23 pm
speaking of lux cv could u use stock ifs lux brass bush then just machine a steel sleave if its different
that way the brass bush could be easily replaced
http://www.lowrangeoffroad.com/index.ph ... shing.html
Post Posted: Fri Aug 16, 2013 7:52 pm
Get a couple of extra bushes made up IF you ever need them.
Vehicle: 04 Grand Vitara, 2.5L, V6
Post Posted: Sat Aug 17, 2013 1:58 am
if u do it get 2 of everything and sell me a kit!
Post Posted: Sat Aug 17, 2013 6:38 am
Sweet gbw! Hopefully those will fit and save making them...
From what I can see they replace the bearing in the hub where the outer shaft goes through?
So that will put it down to just hub spacer and flange adapter. Oh and I'll need a stubby axle kit.
Will do, probably be starting early next month so I can save up some $$.
Post Posted: Sat Aug 17, 2013 10:02 am
If ur making the hub spacer i will take a set
Post Posted: Sun Aug 18, 2013 10:34 pm
The whole front setup from ricksters old comp vit ended up at my place. The anvil is currently under my swb vit but i havent set up the lux cv`s yet, just been too busy :cry:
Post Posted: Sun Aug 18, 2013 10:53 pm
when you part it out or wifey puts it out for hard rubbish. give us a buzz & i'll grab it.
Post Posted: Sun Aug 18, 2013 11:25 pm
Ha! I keep telling het my pile of junk is probably worth more than her running car...so no luck yet matey :deadhorse:
Users browsing this forum: No registered users and 93 guests
