It is currently Tue Nov 03, 2026 9:59 pm
Vehicle: '85 NT sierra
Post Posted: Thu Aug 08, 2013 8:54 pm
Im currently looking at buying what I believe is a 1L sierra. Its a 85 model with a metal grill. The bonnet also appears to be different to my 1.3L NT. is there any other tell tale signs of a 1L? Apart from the obvious being looking at a motor/gearbox which in this case are missing.
Also it's been mod plated for a 2L to remove this do I need to cancel anything with the Qld transport? As I've got 1L running gear to go into it.
Post Posted: Fri Aug 09, 2013 5:33 am
Diff pumpkin is smaller by about 20mm. Can't remember the measurement though, someone else will hopefully know. Brake master cylinder will not have a booster in a 1 litre. Most 1 litres have a metal dash, but being an 85 it might be a type 3 and have a plastic dash.
Post Posted: Fri Aug 09, 2013 6:47 am
The flat bonnet and metal grill are both telltales of a 1L. Also if the airbox is still in the engine bay it is a long cylindrical element rather than a wide but short one that is used in 1.3's.
Post Posted: Fri Aug 09, 2013 7:46 am
The ID plate on the firewall should have the original engine no one it.
Post Posted: Fri Aug 09, 2013 4:22 pm
http://www.gumtree.com.au/s-ad/gympie/c ... 1025231545 it sound like this one
this one is a 1L and not worth 500
And it's abit weird a few thing don't match up being 85 1L no brake booster, small tunnel ,not a plastic dash, no plastic flares
Post Posted: Fri Aug 09, 2013 8:26 pm
x2 it's somewhere between 82-84, it's a type 2 1l.
Run away though. Fuck making a project out of someone elses project. I bet it's made out of bog.
Users browsing this forum: Google [Bot] and 104 guests
