It is currently Mon Nov 02, 2026 1:48 am
Post Posted: Sun Aug 11, 2013 10:50 am
hi all quick question what options are there for stronger cv's and axles for a jimny and where can you get them
thanks for any help
Post Posted: Sun Aug 11, 2013 1:36 pm
Not sure on the axles. I would recommend upgrading to 26 spline and using Sierra CVs. You will need to mod your FWH to allow or teh extra length.
I used trialjimny axles but they are very expensive, and the CVs broke rather quickly.
I think JoeBlow does sets and there is a couple of threads already on this very subject.
Vehicle: Jimny 1.3 - NGV 3door 1.9ddis
Post Posted: Sun Aug 11, 2013 7:49 pm
Some links:
http://www.zanfi.it/modules.php?name=ca ... ath=63_121
http://www.protrack.gr/proionta/suzuki/ ... jimny.html
http://www.trialjimny.com/axle.html
Post Posted: Tue Aug 13, 2013 5:26 pm
whats involver in putting sierra cv's in
whats FWH?
or how much more lenth is needed
Post Posted: Tue Aug 13, 2013 5:31 pm
what dose it say about the pro track ones in the link above i cant read that... someone help please
Post Posted: Tue Aug 13, 2013 5:35 pm
Cut the CV down
Post Posted: Tue Aug 13, 2013 7:44 pm
mmm depends ho much needs cutting off and are the splins the same?
Post Posted: Tue Aug 13, 2013 7:55 pm
Not much. Its just the CV rubs on the locking hub. 31zook got spacers made to stop the rubbing, but its stressing the bolts and they're breaking.
Annoying offroad..
Post Posted: Tue Aug 13, 2013 8:15 pm
i have manual locking hubs so i wonder it it will be ok
and do i have to change the diff gears?
Post Posted: Tue Aug 13, 2013 8:30 pm
They were fitted with manual hubs.
26spline axles will require 26spline side gears.
Post Posted: Tue Aug 13, 2013 9:06 pm
any idea how big the spacers are?
Post Posted: Tue Aug 13, 2013 9:16 pm
can buy them from this bloke :wink:http://auszookers.com/forum/viewtopic.php?f=15&t=15009
hub spacer dribble in this thread along with a few others.
viewtopic.php?f=5&t=29951&hilit=jimny+hub+spacer
Post Posted: Tue Aug 13, 2013 11:05 pm
oops. meant to post it here...
As I am using FWH AND Sierra CV's I had to have quite a thick spacer, 16mm. The spacer is sealed and grub screwed to the locking hub, and sealed to the wheel hub. The 6 holes are a tight fit for minimal movement around studs (not bolts). These studs have a finer thread on the outside for better tightening.
When I had a rough cut 10mm spacer and bolts, I was always breaking bolts. The holes were too sloppy. I have not broken a stud with the new system since. Except to say I stripped the thread because I overtightened one when tensioning. They do need tensioning every so often.
Post Posted: Wed Aug 14, 2013 8:36 am
Well with stronger CVs/Axles ten you have bugsta tim and I can't keep our hubs on. We have 8mm spacers.
After dan made the point of him having no dramas with hub bolts, I'm going to remove the spacer and trim the length of the CV stub. Hopefully more robust.
Post Posted: Wed Aug 14, 2013 2:52 pm
What makes you say they are stronger than what I have?
I have never broken an axle, nor a CV in quite a while. I'm pretty happy with teh setup I have now.
Post Posted: Thu Aug 15, 2013 8:08 am
I run EN26 26spline front axles with Sierra gen5 DT CV's
I assume your 22 spline still? And on Subaru CVs?
Post Posted: Thu Aug 15, 2013 8:37 am
As I mentioned, I am using trialjimny axles, which are 26 spline, and Sierra CVs. Don't know where Subaru comes into it.
I had the ARB side gears re-splined to match the TJ axles. I broke his CVs just driving up the road, so I now have CVs that Derek of suzisport sourced from the states. All he would tell me is that they are HD Sierra. I have only broken 1 at my own fault.
Post Posted: Thu Aug 15, 2013 9:14 am
So there stock 1.3CVs?
Post Posted: Thu Aug 15, 2013 9:20 am
Battle of the jimnys :lol:
Post Posted: Thu Aug 15, 2013 9:53 am
If your CVs/axles are from the UK/England they use Subaru CVs as their upgrade CV.
From the states I'm not sure...
You shouldn't be able to brake a CV no matter what you do due to your diff being so small. The teeth should break off of the R&P well before a DT CV.
Post Posted: Sun Oct 27, 2013 4:01 pm
Can anyone tell me how much has to be trimed off stock 1.3 cv, s and axles to fit in the jimny and do they have to be resplined?
Post Posted: Sun Oct 27, 2013 6:12 pm
The splines are different mate.
Post Posted: Sun Oct 27, 2013 6:28 pm
Realy well thats lame might have to swap side gears and fwh than hope ill be ok
Users browsing this forum: No registered users and 316 guests
