It is currently Tue Nov 03, 2026 5:02 pm
Vehicle: Jimny 08'
Post Posted: Wed Aug 14, 2013 6:45 pm
Ey guys,
Considering buying some gecko rims for my jimny
http://www.geckowheels.com.au/gecko_black.html
It does not have a lift kit at the moment so cant go too big
Just wondering what a decent reasonable rim size would be?
Also any suggestions on other rims that are relatively cheap and look good are welcome
Cheers,
Cam
My Jimny
Vehicle: 2012 jimny
Post Posted: Wed Aug 14, 2013 6:59 pm
21 inch bro.......on a serious note i think most people go 15x7but that could be because its a common rim size??
Post Posted: Wed Aug 14, 2013 7:05 pm
+1 to the 15x7's & a jimny'er will be able to suggest an ideal offset
Vehicle: Jimny 08'
Post Posted: Wed Aug 14, 2013 7:10 pm
cheers guys
My Jimny
Post Posted: Wed Aug 14, 2013 7:43 pm
They are the same design as Sunraysia or ROHS Trak 2
http://www.roh.com.au/trak-2-series.php
Standard offest for 15x7 rims on Jimny is -13. This will keep the wheels inside the stock flares.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Aug 14, 2013 9:36 pm
-13. -15 encourages steering wobble but the tread on the 30"x9.5's is still inside the guards. sorta. makes it easy to adjust the panhard :)
Post Posted: Thu Aug 15, 2013 6:49 pm
Ive got Geckos on my rig cammac.
-13 as already mentioned 15 x 7. Very happy with them.
MY BUILD THREAD HERE!!!!!
Vehicle: 1997 Sierra SJ80
Post Posted: Thu Aug 15, 2013 7:07 pm
viewtopic.php?f=5&t=39179
Post Posted: Thu Aug 15, 2013 8:27 pm
and one +5 for extra street cred... :rofl:
Here you go Atari, stick that in your mangina
Post Posted: Thu Aug 15, 2013 8:47 pm
-11 15x7 rims don't fit on my jimny, the steering arm thing touches the rim.
Post Posted: Thu Aug 15, 2013 8:49 pm
Not anymore bro! thanks for reminding me though :oops: Was fun while it lasted busting around with wheels sticking in/out all over the place without noticing....
Post Posted: Fri Aug 16, 2013 11:49 am
like everyones says get the 15x7 in -13.
for the stud pattern of a jimny, I think you dnt have many options in a 15x7 either.
the -13 offset would keep the backspacing of the rim exaclty as the factory 15x5.5 ones. so the new width of the rim would be towards the outside of the car... if that makes sense :P
Vehicle: Jimny 08'
Post Posted: Sun Aug 18, 2013 2:16 pm
haha cheers guys
my steering wobble is not too bad at the moment, only happens at around 75kph for a few seconds as i accelerate past that speed
But can get prty bad if i brake hard at around that speed
So yeah ill stick to the -13 i think
My Jimny
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Aug 19, 2013 8:12 am
i would recommend taking the time to (book your car in if you have to and) get the king pin bearings replaced and shimmed so the initial torque where the tie road bolts on is 4KG.
i had absolutely no steering wobble before putting on 30's. none. didn't even really know what it was. at first i had a little wobble, but within a week it destroyed the old bearings. i ended up with death wobble, possibly the worst monley had ever seen, and i think thats saying something. i shimmed my own setup after changing the bearings. its not terribly hard, just time consuming to get right. and when i say time consuming, i mean it might take half a day... but trust me you don't want your girlfriend driving a car with death wobble to the hospital. it doesn't work...
Vehicle: Jimny 08'
Post Posted: Mon Aug 19, 2013 12:48 pm
Yeah fair enough, I'll look into it, have Suzuki released any info about the wobble? If I do take it in would be good to have that info on hand haha
My Jimny
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Aug 19, 2013 1:10 pm
download/file.php?id=13713
Vehicle: 2003 Suziki Jimny
Post Posted: Mon Aug 19, 2013 3:12 pm
Just got these gecko rims (10 min ago) gecko 15 x 8 i think on -13.
with the wobble - make sure you get your wheel balancing done. mine was doing that exact same thing. I was about to get the shim kit but got the wheels balanced (properly this time, never going back to the other tyre shop) and it went away.
they are rubbing just a smidge on full lock in the stock guards (but that with 235/75 r15 tyres muddies) will take it offroad this weekend and see how it manages with some flex. and yes they do stick out of the guards ... a bit.
Vehicle: Jimny/110 Landy
Post Posted: Wed Aug 21, 2013 9:10 am
What was the price on the rims? I'm looking at getting some 15x7's very soon as it's new tyre time.
I know everyone opts for -13mm offset, but would -6 work with 235/75's? Logic behind this being 215/75's fit on stock rims which are +6mm. 235's are ~ 10mm wider on each side so need 10mm extra offset to clear the steering arms, which is where the first problem seems to be.
I still haven't lifted the car though. I have a 2 inch lift kit sitting in the shed ready to go in, just no time to do it. How bad withh 235's rub with no lift? Trimming the front bumper and arches isn't an issue.
Post Posted: Wed Aug 21, 2013 12:44 pm
your logic seems fine, but the problem is that you are not taking into account that the factory rims are 15x5.5, so a 15x7 would have a different backspacing by using the same offset as they are wider.
hence why the -13, as it trows out the new width of the rim out of the car, by keeping the same backspacing as factory ones.
If you use -6 in a 15x7, more likely youll have scrubbing issues.... That if you actually find a -6 one in the 5x139.7PCD of jimnys sutd pattern. Another reason why the -13, there are not many options either
Post Posted: Wed Aug 21, 2013 2:33 pm
well the 15x8 (-13) with 235 x 75 r15 on a 40mm lift will not flex properly on the back end, hitting the guards bad so trimming is required- only a tiny bit of scrubbing on the front end, but thats with the swaybar still installed and the mudflaps pinned back. I got quoted $80 per rim, it was $1800 all up for 5 m/t with rims, fitted and balanced.
Vehicle: Jimny 08'
Post Posted: Wed Aug 21, 2013 7:19 pm
Jezza86 wrote:
http://www.auszookers.com/forum/download/file.php?id=13713
cheers will have a read
Was going to ask about pricing aswell haha, seems like a good price for a set of 5 with fitting and balance
My Jimny
Users browsing this forum: Google [Bot] and 423 guests
