It is currently Wed Nov 04, 2026 3:16 am
Vehicle: 95 Vitara Hardtop
Post Posted: Sat Aug 17, 2013 1:15 pm
I have a couple of questions, probly been answered before, but a quick search isn't helping me at the moment...feel free to post a link if it helps.
1. The GV diff has a bit of surface rust on it, (and some oil and some dirt), so I was thinking of painting it. What are others doing in this sort of situation? I have some Septone under-carriage black paint that I was going to use, but getting it suitably clean enough is concerning me a bit?
2. I have ordered one of the support bushes for the driver side which should go in OK, and then is it possible/OK to get generic axle seals for the housing?
3 From reading other posts I am thinking about getting a Spartan autolocker to go in at the same time, if funds allow. I have the 26 spline diff centre, can anyone confirm that spartan do an autolocker to fit this diff centre pls? And where is best place to get one from?
4. Regarding the redundant vac line connection, what is best way to sort this out? ( I recall something about using a small bolt to block the hole, does this require drilling the connection out or does it screw out first?
Thanks for any help.
Mike
Post Posted: Sat Aug 17, 2013 1:29 pm
1. wire wheel the rusty bits, degrease the greasy bits, prep & paint.
2. i'd put my money towards genuine seals, but that's just me.
3. NFI, an autolocker fanboi can answer that.
4. vac line hole is threaded, find a bolt that fits & bung some sealant on it for good measure.
Post Posted: Sat Aug 17, 2013 1:54 pm
Thanks Atari.
The cleanup will take a bit of time then with all the fiddly corners to get into.
Post Posted: Sat Aug 17, 2013 2:45 pm
spartan lockers use original side gears. they are a bit agricultural though.
the same spartan fits front and rear of vit and rear of sierra.
i got a pair from trail tough for under 5 hunge.
Post Posted: Sat Aug 17, 2013 9:25 pm
I run a Spartan front locker in a GV steelie in a Vit.
It is the one on lowrange listed for Sierras/Sammys
http://www.lowrangeoffroad.com/index.ph ... uzsam.html
Users browsing this forum: No registered users and 93 guests
