Joined: Tue Jan 17, 2012 1:40 am Posts: 2979 Location: Darwin, NT
Vehicle: WT sierra, GU CRD
Posted: Tue Sep 10, 2013 12:58 pm
Spookie wrote:
Cant find anything on ebay under Switch light 1 liter transfer case
You are looking for a 1 litre transfer case with a 4wd switch light. I assumed you would search up 1 litre transfers here first to find out what the hell I mean by switch light 1 litre transfer case.
There are none for sale at the moment here or ebay but they do come up, and you will need to move fast when one does. They are an easy and cheap(er) gearing option and hence the demand is high.
Alternatively you could do an after market gear set, + a later model case, way more dear than a 1 litre case at around 150 for the core case and 5-600 for gears plus any new bearings and seals (or shafts ).
Vehicle: Suzuki Sierra 1996 Coily
Posted: Thu Sep 12, 2013 1:52 pm
Hey guys anyone know if a 2 ltr ford focus engine would work/has anyone tried to do this conversion and how hard/expensive is it to legally do an engine conversion in WA
No. Probably not. Very hard. Expensive. Consult engineer
You would be out on your own trying to get that engine to work. I doubt there are gearbox options that will work and you will also have to deal with the factory immobiliser too. Just because you may be able to get an engine cheap doesnt make it worthwhile. Staying within the Suzuki platform with a G16B or a J20A are the best options, its all been done before and is mostly bolt in and do some wiring. If I had to pick something outside what suzuki made I would be after something that was all alloy and was able to take an AW4 auto.
Users browsing this forum: No registered users and 238 guests
