[ 3 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
holdenrules
Joined: Sun Jul 27, 2008 11:30 pm Posts: 181 Location: Rockhampton
Vehicle: 84 Lwb Ute
 Posted: Tue Sep 17, 2013 5:48 pm |
hey all, picked up a complete baleno today for the convertion. now i have read every topic pretty much but still cant find out if you keep the charcoal canister out of the baleno and ditch the sierra one? also wiring what do you do with the wiring for the sensors in the gearbox? will you need to connect theses at all? most people seem to use just the engine wiring harness, what about the 2 fuse boxes under the hood? its a 2000 model twin coil pack baleno. any help would be great as i have searched and still cant find the whole answer. cheers
stockman
Joined: Thu Nov 05, 2009 10:30 pm Posts: 5319 Location: Canberra
Vehicle: 4wd
 Posted: Tue Sep 17, 2013 6:20 pm |
-Use the Sierra charcoal canister, does the same thing as the Baleno one but it's already in place. -You can remove three of the gbox plugs, but not the reverse. -You'll need the fuse box and the relays from under the bonnet. Whether you want to run them as two or combine them that's up to you.
_________________ Watch out or you'll get sued.
losfer
 Posted: Tue Sep 17, 2013 7:53 pm |
you will only need the wiring from the baleno which is relevant to the engine , not the gearbox . you dont need the 2 fuse boxes from the engine bay , all you need is the wiring for the main relay and fuel pump relay and some fuses , most of the other crap can be stripped out . the diagnostic port also runs to one of those fuse boxes , you want to keep those wires as well , you dont have to wire them to anything , they are handy to have if you have problems in future
[ 3 posts ] |
Users browsing this forum: Google [Bot] and 141 guests
