It is currently Mon Oct 19, 2026 10:06 am
Vehicle: 3 Door Grand Vitara
Post Posted: Sun Sep 22, 2013 4:56 am
Hi All :)
If I want 30's on my Jimny with 3" suspension lift...
Then i have to cut the fenders... Is it only in the plastic, or is it also in the steel??
Vehicle: 1985 lwb sierra UTE
Post Posted: Sun Sep 22, 2013 6:36 am
Zukenutter runs 30s and hasn't chopped then pm him :)
Post Posted: Sun Sep 22, 2013 7:12 am
I have 30s and haven't chopped anything. The rear tyres rub a little but it is only a tiny rub, hardly takes the dirt off. The front rubs a little on my bumper however if I trimmed 5mm off it it would be fine.
Post Posted: Sun Sep 22, 2013 7:35 am
shep, what suspension and body lift and arms are you running?
edit: and bump stop extensions?
Post Posted: Sun Sep 22, 2013 7:41 am
To run 32" Simex MP Trekkers, I had to push my firewall back an inch, install 50mm bump stop extenders (using rear bump stops on the front mind you), and push the rear of the front body mount bracket forward. Running castor corrected arms, which were meant to be longer, but aren't, so I found out recently.
edit: Oh, that's with 50mm body lift as well.
Post Posted: Sun Sep 22, 2013 9:07 am
You have 32s and stock gearing :?: must be horrible to drive :wink:
No body lift, haven't found the limit of travel yet so bumpstops are stock. 4" ORA lift with ORA arms. No sway bar.
Post Posted: Sun Sep 22, 2013 9:50 am
I did have an auto case when I put the 32's on. It failed so I put the 29's back on. And I'm not running a 1.3L so its not as bad as it would otherwise be.
Post Posted: Sun Sep 22, 2013 11:13 am
this is a pic from JayKay's jimny
viewtopic.php?f=4&t=5770&start=630
I think the trick from what I have seen is to get some castor corrected arms, that not only would correct caster but it would push your axle forward
Post Posted: Sun Sep 22, 2013 1:57 pm
look at all the cuts in his tread though =) its obviously scrubbing when the wheels are turned.
Post Posted: Sun Sep 22, 2013 3:36 pm
No room for any flex there.
Post Posted: Sun Sep 22, 2013 3:47 pm
To get to the bump stops on 30s you will need to trim the guards.
Post Posted: Sun Sep 22, 2013 7:17 pm
Didnt saw any... The o es there are from a white jimny, hes rubbing on the arb bar tho... Donno how much elsewhere
Vehicle: 2008 Jimny Standard As :-)
Post Posted: Tue Oct 01, 2013 9:01 am
Sure did ARB Bar touched the outer Edge of the Tyre.
2 Things played part.
my Front Pan hard needed re-adjusting because the axle was slightly to one side and the ARB bar needs a slight chop.
The tread only got damaged on the drivers side :x
Once my Bar is chopped, I am going to extend the rear bump stops because there's a slight rub in the rear too
Vehicle: 2011 Jimny
Post Posted: Tue Oct 01, 2013 4:55 pm
look at my build http://www.auszookers.com/forum/viewtopic.php?f=4&t=32090&hilit=skippy 3" inch lift with 30's on -13 rims only place it touches the guards on the rear at the front of the wheel arch and that's with a lot of flex.
Users browsing this forum: Google [Bot] and 292 guests
