https://auszookers.com/forum/
Crawler gears
https://auszookers.com/forum/viewtopic.php?f=5&t=43214
Author:  Spookie [ Mon Sep 30, 2013 9:48 pm ]
Post subject:  Crawler gears
Hey guys
Whats everyones recomendation for crawler gears to go into my 97 suzuki sierra and are they easy to install or is ther lots of modding to the transfer case that has to be done?
Cheers ben
Author:  just_cruizin [ Mon Sep 30, 2013 10:00 pm ]
Post subject:  Re: Crawler gears
I guess it depends on which ones you go for, what size tyre or gear ratio do you want to run
Author:  Spookie [ Mon Sep 30, 2013 10:05 pm ]
I have 235x75x15s on it dont want to go any bigger as i have alot of weight on the car with all the steel bar work
Author:  Matthew [ Mon Sep 30, 2013 10:06 pm ]
You'll need a gear driven case to start with.
Author:  Spookie [ Mon Sep 30, 2013 10:07 pm ]
I have no idea what any of this means sorry never looked into any of it
Author:  Matthew [ Mon Sep 30, 2013 11:23 pm ]
You can't easily lower the gearing in a coily transfer case as it is chain driven. You need to swap in a wide track transfer case.
Try this thread
Author:  Marko_SJ [ Mon Sep 30, 2013 11:27 pm ]
What he meant is that you need a transfer case out of a leafy sierra, as they are gear driven rather than chain driven.
The gear driven ones you can actually put reduction gears in, and aren't they a bit tougher?
Things you might want to specify (apart from tyre size) are the terrain you drive, what engine you are running and how much highway your car sees (not much of a factor I guess as the closer to 4000 RPM you are the happier they are.
For example:
I run 30 inch tyres, I drive a combination of rock (not hardcore) and mud. I am running a g13a, and crave lower gearing for control on the rocks.
Damn: Beaten by Mathew
Author:  Spookie [ Tue Oct 01, 2013 5:53 am ]
Okay cheers mate
I mainly ho to glasshouse so just rocks and mid lots oh hill climbs/declines running a stock g13b
Cheers ben
Author:  Zook_Fan [ Tue Oct 01, 2013 6:46 am ]
Matthew wrote:
You can't easily lower the gearing in a coily transfer case as it is not gear driven. You need to swap in a wide track transfer case.
Try this thread
Fixed :wink:
Author:  Matthew [ Tue Oct 01, 2013 8:20 am ]
Thanks
