| Suzuki baleno wiring https://auszookers.com/forum/viewtopic.php?f=5&t=43242 |
| Author: | holdenrules [ Tue Oct 01, 2013 9:07 pm ] |
| Post subject: | Suzuki baleno wiring |
Hey all sorting out my baleno wiring, got some questions. Do people use the 2 main feed wires to your main high amp fuses? If so where did you put these? And a few other wires that come off one of the blue plugs has got me stuffed. Figured everything else out. Also do you use the stock sierra wiring for the starter motor and alternator or the baleno engine wirin harness ones? Ill try upload photos soon |
| Author: | losfer [ Wed Oct 02, 2013 7:12 pm ] |
| Post subject: | Re: Suzuki baleno wiring |
you dont need to use the main 2 power feed wires which i assume you mean the white with green stripe and white with yellow stripe from the baleno loom . you use the original wiring for the sierra for the alternator and starter. if you post me the wire colours i will tell you what they are and where they belong . |
| Author: | holdenrules [ Thu Oct 03, 2013 8:24 pm ] |
ok mate to easy will get wire colours. i uploaded the photos. |
| Author: | jonfromhamilton [ Thu Oct 03, 2013 8:46 pm ] |
I just did this conversion I used PJ.zook wiring diagram and although I doubted it at one point, it was actually spot on!! I cut out all of those plugs and I think the only wires that I had to solder back together were power supply wires or earth wires. go through PJ.zooks diagram though and understand each part and where it is in your loom, thats what I did anyway |
