Anyone got measurements or quiet certain the alloy pulleys from low range offroad suit the jimny?
Ones im looking at are: 1.6 twin serpentine crank keu-dscpk Tc style power steering pump sst-tcp And also the water pump pulley seu-swpp , says 8v only. Dot see what that could effect in regards to a pulley
Double check the mounting bolts for your crank pulley.
SJ50/SJ70 Sierra with the G13A or G13BA had 4 mounting bolts to hold the pulley on. GTi Swift with G13B, and Vitara with G61A had 5 mounting bolts. I know the Jimny uses a wider crank timing pulley (25mm) compared to the Sierra (19mm), and the Jimny also has a reluctor ring on it for the Crank Angle Sensor, so the Jimny belt pulley might have a different bolt pattern and possibly a different offset.
Aaah good hints, i know the jimny has a 5 bolt and a pin locator instead of a keyway. The vitara or baleno g16a i put in used a 5 bolt and keyway. Low range didnt really help me much in regards to dimensions of their pulleys, maybe in fear of me remanufacturing them. I dont know... :/
They list one for the vitara 1.6 with pin and 5 bolt for the crank. Sadly i didt get a pulley with my donor motor
Users browsing this forum: No registered users and 271 guests
